Old June 2, 2013, 12:06 PM
Soultribunal's Avatar
Originally Posted by KaptCrunch View Post
nada on the baking soda (bubbles) for leaves a acid for your fighting a acid with a acid
rinse really well after to wash away active residue, otherwise will lift off plating on battery tray.
if leaking/swelling battery, is the unit overcharging battery.
You can use Baking Soda mate, its not the best solution but most people don't keep soda ash in their house.
All you get is an endothermic reaction and some residual stuff left over.
Much safer than dealing with the acid on your own.
-ST
www.realhardwarereviews.com
Charge battery outside laptop/ splice power to battery contact clone63 Troubleshooting 4 September 1, 2012 06:24 AM
What to do with a leaky dehumidifier? jcmaz Off Topic 5 June 24, 2011 03:18 PM
Leaky battery - help! Tempstar New Builds 10 April 23, 2011 05:31 PM
[WTT] my w510 9cell battery for your w510 6cell battery elninio Buy/Sell & Trade 0 December 29, 2010 12:16 PM
help with leaky tfc 45 rotary compression fitting! antiacid Water Cooling 7 May 11, 2010 11:49 PM
