-   -   Gtx 660 ti on corsair 650w bronze (http://www.hardwarecanucks.com/forum/power-supplies/60380-gtx-660-ti-corsair-650w-bronze.html)
b0n3tag March 25, 2013 03:59 AM
Hello, i was just wondering if its possible to sli my gtx 660ti (no overclocking) if my psu is only 650w. Btw my cpu is core i5 ivy bridge 3570k (no oc).
Any suggestion?
Soultribunal March 25, 2013 05:05 AM
You are more then sufficient with a 660TI on the 650 (I'm assuming HX model?)
I ran 2 x 460's and an i7 930 off on an HX650 without fail.
-ST
Bond007 March 25, 2013 03:23 PM
If your running all stock (or close to stock) speeds, then I would say your good to go. If you were buying new I would recommend 750w, but 650 would be fine IMO.
Jappetto May 25, 2013 12:59 AM
Depends on the model of psu, but proper quality 650w psu's works for 7950 in xfire. It's more than enough to run a 660ti.
