Old February 17, 2013, 12:54 AM
Dzzope's Avatar
Default Best value of these options?
Quick question..
Akasa Venom 850w(Gold) AK-PA085AM03-UK @$180
vs
XFX 850W XXX (silver) P1-850B-UKB9 @ $155
vs my current (have heard CM aren't as bad as they used to be so not sure about this one, and I got it free, only reason I'm using it)
3 yrs old - CM GX 750 W (not sure of manufacturer code to see what version it is, will check when I get home)
Point being I'm heading home soon and PSU's are cheaper there than here... I may be looking into a second 670 soon and this CM is LOUD too.. suggestions on if the CM is ok(not for dual cards) and which of the other 2 is the better buy?
(Yes we REALLY get screwed on PSU prices)
Old February 17, 2013, 05:26 AM
Bond007's Avatar
There aren't any reviews of the akasa from my prefered psu review sites, but what I did find show it as a decent power supply that does meet gold efficiency, but was far from flawless for all the rails and also a bit below avg for soldering. The xfx is an older seasonic design that is tried and tested. the only downside being slightly worse efficiency IMO.
I would go for the xfx of those two.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old February 17, 2013, 03:36 PM
Dzzope's Avatar
Cheers m8.. thats roughly what I was thinking but I wasn't very sure on the Akasa
Old February 23, 2013, 03:19 AM
Dzzope's Avatar
Right, I'm headed home next week and I've found a few more options that actually come into my price-range..
Opinions on:
The xfx above $155
Rozetka.ua | Antec High Current Pro HCP-850 $165 (This is out of stock, no idea if / when it will come back)
These are from the UK, have free shipping, inc tax but I would have to fit them in my suitcase..
Corsair Professional AX860 Fully Modular 80 PLUS.. | Ebuyer.com $201
Corsair 850W HX 80PLUS Gold Modular PSU | Ebuyer.com $190
Corsair 850W AX850 Modular PSU | Ebuyer.com $178
No idea what they are like:
Fractal Design Tesla 800W 80 Plus Gold PSU | Ebuyer.com $150
Fractal Design Tesla 1000W 80 Plus Gold PSU | Ebuyer.com $207
At the moment I'm on the verge of ordering the AX860
But my budget has to stretch to a 670 DC II as well...
Old February 23, 2013, 05:09 AM
Bond007's Avatar
Not sure about the fractal design ones. The others I would put in this order for quality:
Hx and the xfx<ax850<ax860. Not sure exactly where the antec would fall, but is very good as well ( but out of stock).
There is nothing wrong with any of them. You call if its worth the extra cash.
Old February 23, 2013, 05:21 AM
Dzzope's Avatar
Anyone familiar with the Fractal ones? the 800W for 150 is very tempting if it's any good.
If not I think the 860 platinum is the leader.
Whats there difference Between the AX and HX 850 golds?
Old February 23, 2013, 06:04 AM
JayDeeHobbit's Avatar
I have the AX860i on order for my new PC.
I am also going with 2 GTX670's and thought/hope the AX860i would handle the load.
Here is a AX860i review and this a good site for PSU reviews IMO if you want to search through.
Corsair AX860i 860W Power Supply Review
I got my AX860i for $210.
"Try looking into that place where you dare not look!
You'll find me there, staring out at you!" - Frank Herbert
Old February 23, 2013, 06:29 AM
Dzzope's Avatar
It'll be plenty of power for 2 670's. I'm just trying to figure out the best possible value of PSU's as we get ripped off over here on components and especially PSU's.
I'm leaning toward the 860 (no i, thats a whole lot more) but the AX 850 Gold there and the Fractals are puzzling me a bit as I'm not sure what the story is with them.
Have to say I'm not very into the in's and out's of PSU's but I do want good quality (and much quieter than my current)
Anyone fancy volunteering to scour the UK/Ireland and Ukraine for for the best value high quality 850W+ preferably 80+ gold PSU? (Didn't think so)
Old February 26, 2013, 06:18 AM
Dzzope's Avatar
anyone know anything about the fractal PSU's?
thinking of getting one of these if they are any good:
Fractal Design Newton 800W 80 Plus Platinum Modular PSU | Ebuyer.com
Fractal Design Newton 1000W 80 Plus Platinum Modular PSU | Ebuyer.com
From the bumpf I see Capacitors - Taiwanese and 3yr warranty on the Tesla's and Jap caps and 5 yr warranty on the Newtons.
Would probably go the newtons for the extra warranty but then there is no point in having a long warranty if the PSU is dung..
Old March 24, 2013, 11:15 AM
XFX FTW
i7 3770K, 4.7GHz at 1.33V, ASROCK Z77 Extreme4, 2X4GB Patriot Viper Black Mamba DDR3 1600, GTX 590, 2 Corsair Force 3 120GB SSDs RAID 0,2 Barracuda 7200.10 500GB, Barracuda 7200.11 1000GB Back Ups, OCZ ZX 1250W, Z-5500s, LG Blu Ray Player/DVD Burner, Windows 7 X64 Pro, HAF X. Vision Quest 24" LCD, Optoma H66 Projector
Cooling: TC PA120.2 GT AP15 in push, DDC 3.25/XSPC Res top, EK Supremacy, XSPC Razor, Coolgate CG-240 Swiftech Helix in push/pull, MCP35X
Other options than WD ? botat29 Storage 18 February 24, 2012 12:49 AM
Options... kongfoo911 Water Cooling 2 May 13, 2011 07:35 PM
RMA: What are my options? Gaston Troubleshooting 7 March 22, 2010 12:34 AM
ISP options Cheator Networking 21 August 25, 2008 10:03 AM
Options.... if any? 3.0charlie O/S's, Drivers & General Software 16 July 8, 2007 10:20 AM
