Old January 12, 2013, 02:44 PM
Default Convert 8pin CPU to 4pin CPU?
What do you do when the power supply has an 8-pin CPU connector (NOT 4+4 pin) and the motherboard only had a 4pin header?
is there actually an adapter for that?
Old January 12, 2013, 03:14 PM
The 8 pin SHOULD split and if it doesn't then it SHOULD have a 4 pin.
Old January 12, 2013, 03:33 PM
dustin1706's Avatar
I've never seen a PSU that had a solid 8 pin connector. Weird. Anyway, if your mobo doesn't have room for you to just plug the 8 pin in (and just leave the extra 4 hanging over) pick up a 4+4 extension like this one.
NZXT Premium Individually Sleeved Computer Cables 8PIN EPS/P4 Power Extension Cable
Rig1 in "My System Specs"
Rig2: Q6600, P5DN-D, GTX650, 4GB HyperX, LG BD drive, TT armor case, ek supreme HF, 655 pump, XP
Dell XPS17 - i7 2820QM, 8GB ram, 1920x1080, BluRay, GT555m 3GB, 240gb Neutron GTX, 640GB Seagate, Win7 64
Server - i5 3450, Asus P8Z77-I Deluxe, 4GB DDR3, LSI MegaRAID 9240-8I, OCZ Vertex 4 120GB, 2x SG Barracuda 3TB(RAID1), 2x WD green 2TB(RAID1), Fractal Design Array R2, WHS 2011
Old January 12, 2013, 03:44 PM
If it doesn't split and there's room on your board you can just let the extra 4 pins overhang the connector.
Old January 12, 2013, 05:49 PM
Agree with the above. 4 of the pins will fit, and leave the other 4 over the side.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old January 13, 2013, 08:40 AM
howpet's Avatar
You sure you"re not looking at a 8 pin pci-e connector????
Old January 18, 2013, 09:28 AM
elmorejohn46's Avatar
Buy a converter amazon should sells them,I have one hooked up to one of my old systems
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
Best way to convert USD to CND? Generic User #2 Off Topic 5 September 28, 2012 11:28 PM
2 x 8pin EPS Fudd Rucker Power Supplies 10 November 30, 2011 06:18 AM
Will an EPS12V (8pin) plug in to a ATX12V (4pin)? lowfat Power Supplies 11 July 15, 2010 11:15 PM
Voltage of a 4pin molex cable Phobia Power Supplies 5 May 19, 2009 10:18 PM
4pin ATX12v and 8pin EPS connector magictorch Power Supplies 6 December 6, 2007 03:39 PM
