<~----> GTX 680 SLI and the HX850 - Hardware Canucks
Old November 27, 2012, 01:39 PM
Rollergold's Avatar
Default GTX 680 SLI and the HX850
Given the my system specs and the estimated psu calculation would my 3 year old HX850 still be good enough to power an extra GTX 680 on top of everything else I have in my rig. I know the 680 is quite efficient and lots others say even a good 750 watt PSU is good enough for SLIed 680's but given all the hard drives, fans, and the highly overclocked 920 I own would my 3 year old HX850 still be viable?
System Specs:
Motherboard: ASUS P6X58-E WS
Processor: Intel Core i7 920 D0 @ 4.01ghz
Memory: 24Gb (3x8gb) Corsair Vengeance 1600mhz RAM
Video Card: EVGA geForce GTX 680 SC
Hard Drive # 1: Western Digital Caviar Black 1TB
Hard Drive # 2: Western Digital Caviar Black 1TB
Hard Drive # 3: Western Digital Caviar Black 1TB (Raid 0)
Hard Drive # 4: Western Digital Caviar Black 1TB (Raid 0)
Optical Drive: LG BH12LS38
Case: Cooler Master HAF 932
Power Supply: Corsair HX850 (3 years old)
Sound Card: Sound Blaster Recon3D PCIe
PSU Calculation (from extreme.outervision.com):
Old November 27, 2012, 02:21 PM
supaflyx3's Avatar
You'll be fine.
Old November 27, 2012, 02:54 PM
I say your fine as well.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old November 27, 2012, 03:58 PM
Arinoth's Avatar
I can't remember if the 680s use less power then the 580s, but when I ran sli on 580s I could not run them and my CPU overclocked on a 850W power supply as I would end up pulling too much, cause video drivers to fail/crash and sort of get a soft crash. Seeing as you're using a more power hungry processor then what I'm using (2600k) I'd be very wary of running the 680s above stock.
Old November 27, 2012, 04:42 PM
Soultribunal's Avatar
I personally think you will be okay.
-ST
Old November 27, 2012, 04:43 PM
supaflyx3's Avatar
680 uses about 80W~ less per card on load compared to 580's.
Old November 27, 2012, 05:12 PM
Rollergold's Avatar
One more question, assuming I slotted in another GTX 680 this year and next year If I were to swap the 920/X58 platfrom for LGA 2011/3930k + upgrade the H100 to a custom cooling loop would that warrant a PSU upgrade when I move to LGA 2011
Ok I will keep that in mind Arinoth. I do not plan on overclocking the GPU's however, the slight increase in FPS doesn't really justify the extra power draw or fan noise in my opinion
Old November 27, 2012, 05:52 PM
It would likely still handle it, but with that much invested in a computer I wouldn't keep going with your current PSU after a cpu upgrade as will. If you are running 2011 and SLI 680 I would start thinking about a 1000w PSU, unless you are running it all at factory clocks...at factory clocks on all of it I would be more likely to keep the 850w.
Old November 27, 2012, 06:06 PM
If your main plan is upgrade upgrade, grab the AX1200i and forget about getting another PSU for 7 years :)
-ST
Old November 27, 2012, 06:32 PM
lowfat's Avatar
You'll still be fine. Kepler is ridiculously efficient.
New HX850 VS AX850 martin286 Power Supplies 5 October 1, 2012 01:39 PM
Corsair AX750 vs HX850 Jaydu Power Supplies 15 November 2, 2011 06:46 PM
[FS] Like New Corsair HX850 - $80 + Shipping ImmaPC Buy/Sell & Trade 8 October 3, 2011 08:30 PM
Is the corsair HX850 enough? Chintu92 Power Supplies 20 October 25, 2009 08:09 PM
