-   -   SLI Question (http://www.hardwarecanucks.com/forum/power-supplies/57141-sli-question.html)
overhauled101 October 8, 2012 08:59 AM
SLI Question
I currently have a Galaxy GC GTX 680 and came into a good for a Zotac AMP Edition GTX 680 and was thinking of putting it into my system. Specs on my system are:
i5 3570k OC'd to 4GHz
16 Gigs Kingston Hyper X 1600
Coolermaster Hyper Evo 212
2 TB Seagate Barracuda
240 GB Intel 520
Galaxy GC GTX 680
XFX 750 Pro PSU
The question is will I be able to SLI without having to upgrade to a better PSU? If not then I will probably sell it....the Zotac card.
dandelioneater October 8, 2012 10:00 AM
You'll be Ok with the 750W psu. No worries
overhauled101 October 8, 2012 01:12 PM
10-4. Was thinking it should be ok. Looking forward to trying it out!
bliz October 8, 2012 02:03 PM
Will be ok of course,easily,i think you will use 600W max
Bloodystumps October 8, 2012 03:24 PM
You can always check your usage with this eXtreme Power Supply Calculator
Apathetik October 9, 2012 06:14 AM
Yeah exactly. Wouldn't even pull over 600W I bet. New cards are very efficient! :thumb:
http://www.legitreviews.com/images/r...onsumption.jpg
