Old September 23, 2012, 11:51 PM
elmorejohn46's Avatar
Default Would A Good 850watt powersupply be enough
You can look at my spec's ,but I have a i7-3820 @ 4.725gig on a AsRock X79 Exetreme-4,plus 4 x4gigs of G.sKill DDR1666 and two ASUS GTX-670 DirectCU II and one 256g SSD boot drive and 3-640gig western Digtal Black and two 1TB Samsung drives and a Corsair H-100 and 5 case fans,but they just draw .17amps each.Do you think a SilverStone Strider Gold 850watt modular
http://www.newegg.com/Product/Produc...82E16817256067
Or a Corsair HX850 Gold 850W and it is modular.
http://www.newegg.com/Product/Produc...82E16817139011
Does crosair make the OCZ power supplies or the other way around ,They sure are starting to look a like.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
Old September 24, 2012, 01:20 AM
GT7R's Avatar
A quality 850W will do. And AFAIK the most on the Corsairs are re-branded Seasonics.
That SilverStone is solid, and about the Corsair it's the AX850 which is gold certified, the HX series are 80+ silver.
Old September 24, 2012, 05:18 AM
Soultribunal's Avatar
HX units are now Corsairs PUQ platform done by CWT not Seasonic, though CWT is very high quality and there units have been powering Corsairs HX lineup for a while.
The Silverstone is Enhance, and very good too, so if thats what you are using for your setup its perfectly fine.
-ST
Old September 24, 2012, 11:02 AM
Apathetik's Avatar
Did your 1100W and or 950W die?
ASUS VE278Q 27" LED / DAS Professional Model S Cherry MX Blue Mechanical / Logitech G500 - QcK Mass / Corsair Veng 2000 / Windows 7 Ultimate 64bit
Old September 27, 2012, 12:12 AM
My PC Power & Cooling 950 MK II Blew UP big time ,it was louder then a shotgun and lit my room in the dark.
Old September 27, 2012, 02:32 AM
Adzsask's Avatar
Love my OCZ ZX 850, also used several XFX 850 core edition PSU's in gaming builds and they are super solid.
Old September 27, 2012, 05:33 AM
IMO quality 850 is fine. The fact your other psu blew makes me wonder if for some reason you system is sucking back more power than I would think though.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old September 29, 2012, 07:05 AM
How is it sucking more power ,I have a AsRocK X79 Exetreme-4 ,4 x 4Gigs Of G.Skill 1666 ,I7-3820 and two ASUS GTX-670 DirectCU II ,H-100 CPU Water cooler,256g Cucial bootdrive and 3 westerndigtal 640g drives and two 1-TB drives and 5 case fans that just draw .17amp..I check a power caculater ,which I know dose'nt mean much,One told ne I needed a 950watt and the other said i needed a 771watt.This included my overclocks.I know there is always a bad one in the bunch ,no manner which powersupply i pick.The only other powersupply that went bad for me was a OCZ 700watt ,but there was no boom and no flash.I heard the PC Power & Cooling 950watt was made by OCZ.I have never had a SilvrtStone go bad and like I said the CookerMaster 1100 UCP ,which is over four years old and went though a house fire is still going fine.I just thought being in so much heat might have damaged it since it burnt my power cord off.
Old September 29, 2012, 07:12 AM
stoanee's Avatar
I always pick a psu that is overkill for my needs so that it will hopefully power all my future upgrades.
heatware
Old September 29, 2012, 07:19 AM
That's what I thought I did.But Q.C. was not good on this one,or it just one of those things that just happen.
750watt vs 850watt for GTX 560 ti SLI matt13382 Power Supplies 9 December 2, 2011 07:52 PM
need powersupply help severity New Builds 4 December 2, 2010 04:10 PM
zalman 850watt psu for tri-sli gts 250's kyle_L Power Supplies 4 July 15, 2009 11:26 PM
Need a 12V Powersupply Cptn Vortex Power Supplies 8 January 12, 2009 04:48 PM
