Old September 17, 2012, 01:31 PM
486's Avatar
486 486 is offline
Originally Posted by GT7R View Post
I'd think so too, but I have arranged the airflow so that the front fan directly exhausts the heat from the front of the GPU out of the case, while the top fan is used as an intake (the CPU radiator is located on the rear exhaust and used as an intake, but it never spins above 1500~ RPM even under the most extreme load.
My concern was the wattage, and you've just verified my thoughts that the PSU has more than enough grunt for the setup, thanks
Oh, you put hot air off the CPU rad into case. Good for CPU, bad for every other component in the system. You may damage VRMs on your MB and VC that way.
Make front fan intake, up its RPMs, all others should push air out, including CPU rad fan. Your goal is to make air inside your case cooler.
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Kingstone HyperX 2 x 8GB
Crucial M4 256GB + 128 GB
Sapphire Radeon HD7970
Nec Multisync LCD2690WUXI
Old September 19, 2012, 03:16 AM
GT7R's Avatar
Bought a new intake fan (Sytche gentle typhoon, the 1450rpm version) and flipped the top 200mm fan as an exhaust. Load temps are roughly the same while at idle I've got a 3-4 degrees decrease.
"BF3.3" Level 10 GT Case Mod is "Locked and Loaded" Mnpctech Cases 2 July 12, 2012 12:18 PM
Keyboard types "w " when i press "w" matthew2180 Troubleshooting 14 December 20, 2011 09:21 AM
How do i know if my "Drive Controller" is running in "AHCI mode"? Teo3201 Storage 2 October 8, 2011 09:54 PM
"Wii 2" Codenamed: "Project Cafe" BFighter Gaming 5 April 24, 2011 10:16 AM
3d Vision goes from "gimmick" to "ubiquitous" The RealRollo Video Cards 28 October 21, 2010 03:55 PM
