Old September 13, 2012, 08:26 AM
Default CM 500 watts sufficient?
I have a budget of $250 and I plan on upgrading my motherboard and videocard this weekend.
mobo + ram combo for $119
NCIX Bundle Deal AMD Performance Edition 8GB 2X4GB Memory & Gigabyte 970A-DS3 AMD970 ATX Motherboard - Bundle Deals - 970A-DS3&AP38G1338U2K
videocard for $100
EVGA GeForce GTX 550 Ti Fpb 951MHZ 1024MB 4356MHZ GDDR5 2XDVI-I Mini-HDMI PCI-E Video Card - eVGA - 01G-P3-1556-KR
My currnet PC specs
PSU: Cooler Master RS-500-PCAR-A3
AMD phenom 2 x4 965 BE
Antec Kuhler H2O 620
Gigabyte GA-MA 790x DS4(sata2)
4 gigs of corsair reaper ddr2 ram @1066mhz
BFG Geforce 9600 GT oc @ 675mhz 512MB
boot drive: OCZ agility 3 120 GB
storage: seagate baracuda 500GB
Old September 13, 2012, 08:45 AM
GT7R's Avatar
Should not be a problem, just to make sure - what is the exact PSU model?
Old September 13, 2012, 08:54 AM
Fudd Rucker's Avatar
Im currently running an i3 540 @ 4.6ghz with a GTX 470 on a TT TR2 500w psu lol. Zero issues after 6 months so far.
I couldnt think of something snarky or interesting to put here this time around.
Old September 13, 2012, 08:56 AM
eXtreme Power Plus 500W - Cooler Master - Leading Provider of Computer Case | Cooler | Power Supply
Old September 13, 2012, 08:57 AM
dandelioneater's Avatar
The wattage should be fine. Hopefully the 12V rail can sustain a 470 ( I'm sure it can though).
Old September 13, 2012, 09:00 AM
GT7R's Avatar
Will handle your setup no problem.
Yeah you're fine wattage wise.
Old September 13, 2012, 09:16 AM
Thanks.
Any suggestion on what other gpu card I should get? with slightly better performance and price?
Old September 13, 2012, 09:21 AM
Soultribunal's Avatar
Wattage wise you shoudl be okay, I would just be concerned about the long term life of that system. Those CM units were far from the best 500W units out there.
-ST
www.realhardwarereviews.com
Old September 13, 2012, 11:13 AM
cooler master is not reliable for power supplies
Are noctua fans sufficient as a PSU fan? geoc Power Supplies 6 March 29, 2012 08:07 PM
Home Karokie set up? Is this sufficient? yanhchan HTPC Systems & Software 0 February 17, 2011 07:54 PM
Sufficient or insufficient? JMCD Water Cooling 20 August 15, 2010 07:38 PM
Sufficient Power fishingfanatic New Builds 4 March 14, 2010 03:23 PM
Is my PSU sufficient? bazookaworm Power Supplies 6 November 30, 2008 02:42 PM
