Originally Posted by taimoorali007 Hmm...Thnx but still waiting for humid days to pass away |
Wall receptacle safety ground is mostly for protecting humans. It does not earth a surge for many reasons including excessive impedance (ie 'more than 10 feet' long). Ignore all 'not safety grounded' receptacles. Worry about another ground that does the protection - earth ground.
Grounding anything inside a house only makes that appliance a best path to earth. A lightning strike, often far down the street to AC wires, is a direct strike 'incoming' to every appliance. Is every appliance damaged? Of course not. To have electricity means both an incoming AND an outgoing path to earth. Earthing any appliance only makes it an easiest appliance to damage.
Earth the surge; not an appliance. That means every incoming wire (including all three or more AC wires) makes a short connection to earth ground. Either directly (ie cable TV, satellite dish) to earth with a wire. Or via a 'whole house' protector (ie AC electric, telephone). Then a surge is harmlessly earthed BEFORE entering the building. Then a surge need not hunt for earth destructively via appliances.
Protection means hundreds of thousands of joules dissipate harmlessly outside the building. That's how protection is done in any facility that cannot have damage. Worry only about the earth ground that must be short (ie'less than 10 feet') from each utility wire to the one and only earthing electrode. The all so critically important single point earth ground.
