Old July 26, 2012, 01:36 AM
Default Would this PSU be able to feed all my components?
GENERAL SPECIFICATIONS:
COOLING Fan(s):Single, 120mm PWM Controlled FDB FanTOTAL POWER OUTPUT:400W TOTAL CONTINUOUS OUTPUT @ 40°COUTPUT CONNECTORS:MAIN 20+4PIN, (1)4+4 PIN, (1)PCI-E 6+2Pin, (4)SATA, (3)MOLEX 4-PIN, (1)FDD 4-PINNVIDIA SLI SUPPORT:YESAMD/ATI CROSSFIRE SUPPORT:YES80PLUS CERTIFIED:YESMODULAR CABLE:N/ASAFETY APPROVAL:CE, FCC, CB, UL, TUVMTBF:100,000 HOURS @ TYPICAL
I will need to know if those specs are good enough to power the following components
(both in terms of wattage power but ALSO in connectors)
- Motherboard
- CPU
- 6 HDD Mechanical Drives
- 1 SSD
- Optical Drive
- 1 Graphic Video Card
- TV Tuner Card
- eSata Card
Peripherals would be 2 HD Monitors and a 4 Bay External enclosure with esata connection
Thank you
Old July 26, 2012, 01:47 AM
Perineum's Avatar
Well you left out a lot of important information....
your CPU.... is it an Atom processor or is it a 6 core monster OC'd with HT?
Also, your video card.... is it a Matrox Millenium or a GTX480?
And finally..... what brand PSU are you talking about?
A 400W Corsair, Silverstone,or Seasonic is going to be a hell of a lot better than a L&C or Solytech unit.
Judging by those stats it's not a name brand, but I could be wrong. Most of the good ones are tested at 50C and not 40C, I believe.
Old July 26, 2012, 03:16 AM
Answering to Perineum's post:
- My CPU is Intel i5 3570 no overclocking.
- Video Card ia a modest nVidia GeForce 240GTS
- PSU is found in here >> http://www.fspgroupusa.com/download/...U-400_SPEC.pdf I an not aware about the build quality of this FSP brand. It was suggested to me by NCIX staff for its 90% > efficiency.
Thank you
Old July 26, 2012, 05:46 AM
misterd's Avatar
You should be plenty fine with that. If you jumped to a fancier graphics card and started hardcore overclocking then you would need to upgrade.
| i7 920 / Noctua NH-U12P / Asus Rampage 2 Extreme / 24GB Corsair Vengeance / Asus HD5870 / Corsair 600T / Corsair HX850 / Intel 520 240GB |
| X2 5000+ BE / Passive Scythe Ninja Mini / Gigabyte MA78GM-S2H
/ 4GB G.Skill Pi / Fractal Core 3000 / Corsair CX430-M / Intel X25-M 80GB |
| i7 2700k / CM 212+ / Asus P8Z68 Pro-M / 8GB Corsair Vengeance / Antec SLK3700AMB / Seasonic M12-II 430W / Samsung 1TB |
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old July 26, 2012, 10:32 AM
Perineum's Avatar
That PSU seems to be alright.
You could play with this: eXtreme Power Supply Calculator
According to what I just filled out based on your system at 90% load (which will only happen on startup) you'll do just fine with that PSU.
Need feed back on a HD plasma ASAP biff Display Units 7 May 28, 2011 07:13 AM
Live Benching Feed ... PURE Style r0bc Overclocking, Tweaking and Benchmarking 19 February 5, 2010 05:20 PM
9.7 catalyst feed back bc_tileguy O/S's, Drivers & General Software 18 August 11, 2009 01:03 PM
[FS] Time to feed the "Need to Upgrade" Sale!!! mattlef Buy/Sell & Trade 16 August 1, 2009 03:15 PM
TV Tuner to rec digital feed Wiked HTPC Systems & Software 4 October 14, 2007 12:40 PM
