CX 600W V2 for 6950 crossfire? Hey , I was thinking of picking up an additional 6950,But not sure if my PSU would be up to the job?..i think probably not. Corsair CX 600W V2 My rig specs,Not overclocked but might do in future. Quote:
After experience with the same setup, 650w is the very lowest I'd recommend. |
Yea I would think that your 600 should do it but maybe getting close to maxing out . here is a link to a online calculator for PSU wattage but I think you should be fine. also keep in mind the age of the PSU will be a factor . |
I would say no. The psu only has 2 pci-e connectors and you will want four for two 6950. From personal experience, when I added a third 6950 onto my corsair ax850 it blue screened, when 2x6950 were working flawlessly. I do not know if it was not enough wattage or the molex to pcie connector that came with the card not being robust enough for the card's needs. But I would not be surprised by hard lockups and blue screens running a 3570K with 2x6950. |
Each card can use anywhere from 200 to 240 watts. I would say to be on the safe side and not stress you PSU, I would be looking in the 700watt range to make sure it's will handle your system and both of the cards going at once and not run out of power. Always make sure you have more power then what you need. A PSU running at maximum is NOT running at it's most power efficent. |
no. Not even close to enough amps on the 12v rail. I am surprised it is running 1 6950 with out a problem. |
No. My (2) 6950's running BF3 with ultra settings hover around 580 watts of the wall. With furmark, its hovers around 592 watts. So you need a min of 750 watts at least. |
It is just barely enough. A 6950 pulls 38-40 amps on the 12volt. a cx600 only has 40 amps on the 12v. Just enough. The gtx 570 for example says minimum 600watts but needs 42 amps in the 12v. These low end power supplies will run this stuff but for how long this is a bottom of the barrel psu running 300 dollar gpu. Why would you subject your card to this? |
We are telling him to pick up a Quality Brand Name 750 watt PSU which will more then work well in his case. To the OP: I invite you to take a quick check on the web on other websites that review your type of card and see how much power it pulls from a total system. The card normally pulls around 200 watts so you can get an idea of the total system draw when you want to run 2 of them. Here are some examples: http://www.hardwarecanucks.com/forum...review-15.html http://www.************/article/2011...card_review/12 Please take all of this into consideration when you make your choice of your PSU and get a good quality brand name unit. Ignore tianfeng, i'm sorry but he really doesn't know what he is talking about. |
| All times are GMT -7. The time now is 10:44 AM. |
