I would honestly suggest getting something like an HX or AX750 or other equivelents out there.
My old rig (i7 930, 460 SLI) pulled when gaming on Eve 510w's maxed out (confirmed by APC , Kill-a-Watt, and Eaton UPS Tester)
Given that the 6950 is a little more power hungry (though not by much) so I would not want to be running it that close on a 600 V2 CX. They are more of a bugetary Corsair PSU anyways so although my HX650 lived up to the task I wouldn't want to strain the CX that much.
Originally Posted by tianfeng It is just barely enough. A 6950 pulls 38-40 amps on the 12volt. a cx600 only has 40 amps on the 12v. Just enough. The gtx 570 for example says minimum 600watts but needs 42 amps in the 12v. These low end power supplies will run this stuff but for how long this is a bottom of the barrel psu running 300 dollar gpu. Why would you subject your card to this? | |
Originally Posted by tianfeng no. Not even close to enough amps on the 12v rail. I am surprised it is running 1 6950 with out a problem. | |
Sorry mate but going by your calculations 38-40 Amps drawn by a Card at 12v is 480W's which is WAY beyond the cards design spec. You're calculating the draw incorrectly and adding confusion to the fray.
A CX600 is more than capable of handling the non X-fire system. And if in doubt he can spend the $30 at a canadian tire and get a Kill-a-Watt to see his draw.
-ST
