-   -   what power supply should i get ,plz help:) (http://www.hardwarecanucks.com/forum/power-supplies/55300-what-power-supply-should-i-get-plz-help.html)
karolis July 6, 2012 01:35 PM
hello everyone i need your help for my final choice. i need psu that will be good for my build and run every componet witouth any problem:)
my build
i7 3770k
sabertooh z77
h100 16gb ram corsair 1600mhz
gtx 680 2gb ,i only be using one.
wester cavier blac 1 tb samsung 830 128gb ssd
corsair 600t
so how much do i need W PSu:) and which one i liek corsair ones
wirerogue July 6, 2012 01:37 PM
corsair has it's own psu calculator
Learn & Explore
karolis July 6, 2012 01:51 PM
can you tell how much i need becouse i can chose the rams.
NSdeadly1 July 6, 2012 02:07 PM
750 watt should be fine 850 if you want to be sure and in case of SLI/Crossfire later on. Look at the Corsair AX750 or psu's from Seasonic and XFX.
Adzsask July 6, 2012 02:09 PM
Quality 750 watt PSU, XFX core are usually on sale.
karolis July 6, 2012 02:22 PM
ok thanks for help guys
wirerogue July 7, 2012 02:34 PM
if you are only running the 1 video card, even 650 watts is overkill.
bigFOIG July 8, 2012 04:04 AM
I'm sure a 650w would work with that set-up.
Bond007 July 8, 2012 05:35 PM
Yeah I also say a quality 650w powersupply.
Soultribunal July 9, 2012 09:23 AM
HX650 and you will have no worries at all.
-ST
