Old April 4, 2012, 02:26 AM
Default Will a Corsair TX650M handle the following?
Main hardware:
- Intel Core i5-3570K at 5GHz (although it will be less, assume the power consumption of an Intel Core i5-2500K at 5GHz)
- DUAL AMD Radeon HD7850 2GB at 1GHz for the core
Other little stuff:
- 8GB (2X4GB) of Corsair Vengeance LP (1600MHz 1.5V 9-9-9-24)
- ASUS P8Z77-V (I hope that the 8+4+2 of this motherboard will handle 5GHz)
- Intel 520 SSD and a 1TB Seagate Barracuda
- Corsair H100
I know that even if it works, it may be tight... But I personally think it's alright.
What do you guys say about a TX650M pulling this setup?
I know it will be fine at stock, but I'm curious about the overclocks. Thanks!
Old April 4, 2012, 02:32 AM
supaflyx3's Avatar
Take a look at this review: AMD Radeon HD 7870 & HD 7850 Review
At load 1 7850 is consuming 247W, I believe SKY was using a 2500K in that benchmark, if ivy is anything like sandybridge when it comes to power consumption you'll do just fine with 2 in crossfire on a TX650M.
Old April 4, 2012, 04:29 AM
Apathetik's Avatar
Ivy is supposed to draw less power then Sandy by a bit, so yah that will be fine.
Old April 4, 2012, 04:40 AM
Bond007's Avatar
I would say it will be good to go with dual 7850 and the setup as you listed.
Tags
consumption , tx650m
can Corsair 750W handle this? SquattingDawg Power Supplies 13 November 24, 2011 01:03 AM
i wonder how this would handle folding... BrianHanna HardwareCanucks F@H Team 4 December 14, 2009 08:35 PM
Can a tx850 handle this?? Cowboy Power Supplies 10 July 9, 2009 02:33 PM
Can my psu handle 285 sli? OpTioN Power Supplies 11 May 15, 2009 10:08 AM
Will my PSU be able to handle the new upgrades? k1ddo Power Supplies 8 January 9, 2008 10:29 AM
