Old March 18, 2012, 09:52 AM
JD JD is offline
Default 65W enough for...
So I currently have an Antec ISK300-65 but I'm looking at giving it a bit more horsepower than the current Atom D525 (Intel D525MW) that it houses.
I'm looking at the following:
ASUS P8H61-I Rev 3.0 mITX H61 LGA1155 DDR3 PCI-E16 SATA2 USB3.0 HDMI DVI VGA Audio Motherboard - ASUS - P8H61-I REV 3.0
Intel Celeron G530 Dual Core Sandy Bridge Processor 2.4GHZ LGA1155 2MB Cache 65W Retail Box - Intel - BX80623G530
Mushkin Enhanced Silverline Stiletto 4GB 2X2GB PC3-10666 DDR3-1333 9-9-9-24 Dual Channel Memory Kit - Mushkin Enhanced - 996768
OCZ Petrol 64GB SSD
WD Scorpio Black 7200RPM 500GB
Gelid 80mm fan
Intel Gigabit CT (maybe)
Now I think that shouldn't use over 65W, even under full load, but curious to see what others think. It'll be running Server 2008 R2 as a Domain Controller, so definitely no GPU load, just CPU load. And I could always under-volt/clock the CPU if necessary to keep the power consumption down.
Old March 18, 2012, 11:15 AM
Arinoth's Avatar
I could see this thing hitting 65W if you were at 100% cpu load, seeing as you also have 2 storage devices, though I "think" you should be fine with a 65W psu. If you have a kill-a-watt meter and a spare psu you could see what the draw is, and if it's under use that former psu?
Here I am: here I remain
Old March 18, 2012, 03:33 PM
JD JD is offline
windwithme did a post with a Gigabyte mATX H61 and G530 and it pulled 53W under load and 32W with the CPU undervolted to 0.888V or something like that. So I think it should be fine.
Also, the 65W PSU in the case isn't easily changeable. It basically uses a laptop power adapter and a DC-DC conversion board inside the case to provide the necessary connectors/voltages. The board inside though is rated at 150W, but the power adapter is only 65W. I'm sure I could find a 150W adapter somewhere to use instead if necessary.
And I do have a power meter, but I don't have the hardware ;) I guess I could buy it and deal with the power issues once I get it.
Old March 18, 2012, 03:57 PM
KaptCrunch's Avatar
you could stuff a 500 watt psu in there
or 300 watt but i thinks is 20 pin ATX
Old March 18, 2012, 06:26 PM
JD JD is offline
That would take a lot of modding to fit in it.
Here's a shot of the PSU board:
And of the overall case:
As you can see, not much room to play with!
Old March 18, 2012, 06:46 PM
Check SPCR for Sandy Bridge undervolting guides.
IIRC they had a review on an undervolted i3 2100 (65W) vs i3 2100T. (35W) It should be fairly easy to cut your TDP in half since you don't have hyperthreading.
Old March 18, 2012, 07:14 PM
KaptCrunch's Avatar
i get the dimensions of 1.75 L x 3.25 W x deep 7.325 inches for the 300 watt
it should lay cross case or same spot of org
Old March 18, 2012, 07:35 PM
tianfeng's Avatar
There is an Antec ISK300-15o, I had to order one for a customer at memx. There must be a way to get that 150 watt power supply without the case.
Old March 18, 2012, 07:45 PM
JD JD is offline
Good MS Paint skillz ;)
I guess it could, but then the power outlet would need a hole cut out of the side?
Yeah but it's out of stock and well this one I have is perfectly fine. All you need is the "upgraded" external AC adapter, everything else is the same. Sadly Antec doesn't just sell the adapter on their spare parts page, but maybe I could contact them to get one.
Old March 20, 2012, 04:23 PM
JD JD is offline
Well I just got the Antec ISK100 today, nice compact case with a 90W PSU. Definitely much better value than a PicoPSU + Mini-Box as this was only $80. Still able to house 2x2.5" HDD even, and has a nice 100mm fan on the side so cooling shouldn't be an issue at all. Tons of mesh/ventilation holes too.
I figure 90W should be much safer for a G530 + H55. Should be some breathing room at least!
