Old March 11, 2012, 03:36 PM
Default Seasonic X760 can it power the following
I currently have a Seasonic X760 and it has to power the following.
i2600k overclocked
16GB ram
3 HDD
2 SSD
1 Optical
1 memory reader
1 swifttech mcr 320 pump/rad combo
5 fans, 3x120mm, 1x140mm and 1x230mm
GTX 580
If I replace the GTX580 with a Radeon 6990 with a waterblock, will the PSU have enough power?
Did you try turning it off and on again?
Old March 11, 2012, 03:47 PM
SugarJ's Avatar
It should power your spec'd stuff no problems. That's probably about a 500w draw.
Old March 11, 2012, 04:59 PM
I told you on the pm. My system Pulls ~ 550W Under Load. Thats without calculating power supply efficiency.
Old March 11, 2012, 05:25 PM
Bond007's Avatar
Good to go in my opinion.
Old March 12, 2012, 04:37 AM
Easily, granted the 6990 will draw some more power, put around 600w of use +/- so it should still be leaving a fair amount of overhead.
Old March 12, 2012, 11:38 AM
GT7R's Avatar
Yes, with ease.
Will the Seasonic X-460 be enough? lsquare Power Supplies 7 October 25, 2011 01:51 PM
Seasonic X-560 enough to power 560CU Ti & i5 2500? blinkdagger Power Supplies 11 June 24, 2011 10:40 AM
Seasonic overheating Lanboy Power Supplies 14 May 29, 2011 06:34 AM
