That makes sense, thank you muchly. I've seen you posting over at a certain retailer's forum, always helpful :)
So can I assume that psu's that don't have a combined 12v rating listed have literally taken the total 12v amperage/wattage and divided it by 2? So if I'm looking for a psu with at least 26a on the 12v rail, and I find one with say 14a on each but no combined value, I can safely assume its 28a? I guess keeping in mind the total wattage of the psu. Actually most psu's do list the total wattage for each division(?) of the psu, so I guess that would be the upper limit?
For example:
So 481.5 max amps for the 12v rails (but combined with the 3.3 and the 5 - what runs off the 3.3 and the 5?)
Or maybe I can ask you this, so it regards specifically to my situation; what would you recommend for a
minimum watt psu and minimum 12v amperage with an amdx2 4200, 2x1g pc5300 ram, one sata hd, one dvd (multi) burner, one card reader (sd, compact flash, etc), on board realtek 7.1 audio - considering an basic stock evga 8800gt (which recommends minimum 450watt psu with 26a on the 12v rail).
I'm on a budget, so I'm looking for a cost effective psu plus gpu combination. And I'm trying to educate myself on psu's ;)
