Old February 20, 2012, 03:09 PM
PerryC's Avatar
Default Power Supply Tester
Been tinkering with a friends computer for a little while now, I now suspect that the psu is faulty/dying and is killing the mobo on a full shut down.
Can anyone recommend a decent psu tester? I have been looking around and there are lots available, just want to make sure that I get a fairly decent one.
The oath to serve your country did not include a contract for normal luxury, and comforts enjoyed within our society. On the contrary it implies hardships, loyalty and devotion to duty, regardless of rank
Old February 20, 2012, 03:20 PM
There isn't.
You can use a multimeter and hope for the best.
Old February 24, 2012, 06:33 AM
LoTech's Avatar
Thermaltake - Global - Dr.Power II - AC0015
this is what I would recommend.
Old February 24, 2012, 06:41 AM
Does that put load to the power supply? All most of those do is tell you the voltages of how the power supply is running.
The load voltages are more important.
Old February 24, 2012, 08:22 AM
Arinoth's Avatar
Yep, without a load you can't check the load voltages as well as the current being delivered. Sadly my own device which would allow a power supply to be tested is stuck with trying to measure the pci-e slot of the mobo power usage... (keeping it low cost)
Old February 24, 2012, 06:03 PM
PerryC's Avatar
Forgot that I had started this. Hmm, too bad, I was hoping to be able to say for sure the psu is the original problem.
Old February 25, 2012, 06:43 AM
Arinoth's Avatar
Yeah, unfortunately there is nothing on the market right now to accurately test a loaded psu other then throwing parts into it and stress testing the system and swapping parts to find the culprit.
Old February 25, 2012, 06:48 AM
KaptCrunch's Avatar
carbon pile load tester will do it but 500 amp is over kill
Old February 25, 2012, 06:54 AM
KaptCrunch's Avatar
brown out comes to mind, first borrow a UPS unit (Uninterruptible power supply) to see if thats your issue of low voltage dips (like freezer kicking in and sucking up the juice)
Old February 25, 2012, 07:50 AM
PerryC's Avatar
Might have to take this to the troubleshooting area.
All the other components...ram, cpu,gpus,hdds work fine on another motherboard. When I power up this motherboard all fans spin, leds light up, board refuses to post. Swap other compnents onto this board...including a known working psu and still refuses to post.
The reason I suspect it was the psu in the first place for days before the failure the board was working fine, no issues. His daughter shut the computer down, when they went to restart it, nothing.
Second board in the last little bit, wish I had thought of the possibility of psu failure the first time. If it matters its a Thermaltake Toughpower 850.
[FS] Various Computer Components (Nothing right now) Asad_A203 Buy/Sell & Trade 18 June 8, 2012 08:02 AM
OCZ Technology Unveils the PC Power & Cooling Silencer Mk III Power Supply Series Sam_Reynolds Press Releases & Tech News 8 November 9, 2011 07:48 PM
PC Power & Cooling Unveils New 760W Silencer Power Supply FiXT Press Releases & Tech News 3 December 18, 2010 03:53 PM
