<~----> Any info on these Seasonic? - Hardware Canucks
Old February 12, 2012, 05:45 PM
Ravenor's Avatar
Default Any info on these Seasonic?
Greetings,
I looking to replace my wife power supply and I am working on a budget. I know Seasonic make reliable high-end PSU's but i can't find too much info on these. Have any of you guys sued them before? Is it Quiet(she wants it really quiet)?
Canada Computers | Power Supplies | Seasonic SS-600ET 600W 80 PLUS BRONZE Power Supply - OEM/BULK 3YR.MFG.WARRANTY
500-600 watt is the range im looking for but under $100.00. Any positive feedback would be appriciated.
Old February 12, 2012, 05:59 PM
3.0charlie's Avatar
If she want really quiet, then drop a few more bucks and get this one: Canada Computers | Power Supplies | Seasonic X-560 Fully Modular 80PLUS Gold 560W PSU (SS-560KM Active PFC F3).
The fan will not spin unless 50% load is achieved. That's the PSU I use in my Wife's rig. And a happy Wife is a happy (husband) Life.
Old February 12, 2012, 06:04 PM
Originally Posted by Ravenor View Post
Greetings,
I have bought my first seasonic and I will be buying them again in the future.. really really good!
and I hope you mean "used" not "sued" :)
-joe
Old February 12, 2012, 06:07 PM
tangrisser's Avatar
I've had the SS-600ET until recently. It's a decent power supply for the price but there are surely better ones out there even at few dollars more. I would agree with 3.0charlie or try this guy below:
Seasonic S12II 520W EPS12V 20/24PIN ATX Power Supply Active PFC 80+ Bronze 6+8PIN PCI-E W/ 120MM Fan - Seasonic Electronics - S12II 520
I'm a big fan of Seasonic power supply and this was one of my favorite although I wasn't aware about the X-560's fan not spinning unless 50% load or higher.
Check out my SALE page
Old February 12, 2012, 06:11 PM
3.0charlie's Avatar
I use the S12II in my file server, and I can hear the PSU fan over the HDD chatter.
Get the X560. You won't regret it.
Old February 12, 2012, 07:05 PM
Ravenor's Avatar
Awesome, thx guys, that's what i needed to know
Old February 12, 2012, 09:58 PM
Rosewill's Capstone units are currently leading the budget segment. They're based on SuperFlower Golden Green platform, which's used in NZXT Hale90 units. Shoot for the Capstone 550. It's better than the X-560 as well. It runs cooler, has comparable performance and sells for cheaper.
Old February 18, 2012, 08:03 PM
NZXT HALE82-series PSU's are all basically rebranded Seasonic M12 II models.
You can pick these up pretty cheap when they have both IR + MIR at some retailers.
Old February 20, 2012, 05:59 AM
486's Avatar
486 486 is offline
X-560 / X- 660 / X - 760 will not spin their fan up to 30% of the rated load in well ventilated case. At 50% of the load on 560, there is at least 30W worth of heat to be dissipated from PSU. That will require fan.
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Kingstone HyperX 2 x 8GB
Crucial M4 256GB + 128 GB
Sapphire Radeon HD7970
Nec Multisync LCD2690WUXI
Will the Seasonic X-460 be enough? lsquare Power Supplies 7 October 25, 2011 01:51 PM
Corsair or Seasonic??? jcmaz Power Supplies 6 October 8, 2009 04:13 PM
Seasonic M12 500W jcmaz Power Supplies 6 October 4, 2009 11:49 AM
