<~----> Antec Earthwatts 500W Noisy - Hardware Canucks
Old February 7, 2012, 08:18 AM
geokilla's Avatar
Thumbs down Antec Earthwatts 500W Noisy
Has anyone had their Antec Earthwatts 500W go noisy on them? Is this a sign that my PSU is dying? The sound seems to be coming from the PSU fan. It's so loud it's not even funny. Smacking the back of the PSU seems to temporarily fix it, but that's it.
It was fine last night and relatively quiet, but now it sounds like a 6000RPM machine.
Old February 7, 2012, 08:31 AM
is the fan replaceable?
Old February 7, 2012, 08:37 AM
Silent_Avenger's Avatar
Try and measure the fan usually they're 80-90mm on the earth watts. If you don't have anymore warranty on it pull it appart and see if the connection for the fan is hardwired or just plugs into a header. However if you no longer have a warranty on it you may want to consider replacing it but that's just my preference.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old February 7, 2012, 08:45 AM
Soultribunal's Avatar
Yeah its not the PSU itself, its gotta be the bearings in the fan going. That is usually indicated espically when hitting it allevates the noise.
They should have, 3 years I think for warranty. Send it in for RMA.
If not you might be able to get a 80mm to fit it, I don't think they are special fans in there so long as it can wire to the board correctly.
-ST
Old February 7, 2012, 08:47 AM
geokilla's Avatar
I should still have warranty for it, as it was bundled with the Antec Sonata 3. Turning off the computer than turning it back on, the noise is gone for maybe 5 minutes then it returns.
Uh what a bad timing for this to happen. Got 3 midterms this week and next Monday >.<
It's a 80mm fan. Why they chose 80mm... Who knows.
Old February 7, 2012, 08:48 AM
Saves costs, for the wattage of the unit its fine.
It has nothing to do with the size, the real question is what type of fan is in there.
Bad fan choices make for noisy PSU's.
-ST
Old February 7, 2012, 09:57 AM
RMA or just buy a new fan.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old February 7, 2012, 10:19 AM
Yea could probably be a defective fan that was installed and is failing early. I have the same problem with my Radeon 4890 fan on cold starts it rattles like crazy until it warms up. Here's some arctic cooling fans that are pretty cheap depends if you need 80mm or 92mm.
Arctic Cooling Arctic F8 80MM Case Fan 3PIN 2000RPM - Arctic Cooling - AFACO-08000-GBA01
Arctic Cooling Ultra Quiet 90MM Case Fan Fluid Dynamic Bearing 1500RPM 26.7CFM 3PIN - Arctic Cooling - AF9225L
Also you say it's still under warranty and having to open the psu to replace the fan will probably void any warranty seals just to give you a heads up.
Old March 28, 2012, 02:36 PM
geokilla's Avatar
Well, the fan finally died. Now I have to spend a good hour to change PSUs...
Old March 28, 2012, 03:08 PM
That's an annoyance for sure, but its better than a dead PSU. Going to RMA, or rip it apart and try to replace it?
Antec Earthwatts 750 Socrates_Johnston Power Supplies 10 November 26, 2010 06:55 AM
Antec Earthwatts 430 concern Wolfx25 Power Supplies 3 October 29, 2010 07:00 AM
Antec Earthwatts? laplapmax Power Supplies 4 October 26, 2010 08:35 PM
Is the Antec Earthwatts 500W enough? Song Power Supplies 7 September 29, 2007 07:34 PM
