Old February 1, 2012, 11:51 AM
Mr. Cipher's Avatar
Default Corsair HX1000 - Canada to UK
Hey all,
Long time no see. So it looks like I have an opportunity to move to the UK but I don't want to replace my rigs if I can avoid it ($$!). I recall older PSUs used to have a red switch to change between 110v/220v, but from what I read my HX1000 can do that automatically. So what I need is a PSU to Power Outlet cable with the UK standard prongs rather than N.American prongs (apologies for using the incorrect terminology).
After some search I came across this:
Canada Computers | Cables & Adapters | Power Cord (British Standard)
Does anyone have any experience with this? Would it work?
Also, if anyone has thoughts on my LCD monitors (i.e. would it be sufficient to change the power cable or would they fry and I should instead get N.America to UK adaptors instead) that'd be appreciated. I realize I'm combining two separate topics in one post but they both relate to power, so I guess it's as good a place as any
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | Radeon HD 6870 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz |
BFG GTX 295 | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Old February 1, 2012, 11:56 AM
The back of your monitor should have all the electrical specs. If it says it can handle the higher input voltage, all you have to do is change the cable.
Do check that it can handle the frequency as well, though I'm pretty sure the standards are the same in the UK and Canada.
Old February 1, 2012, 11:58 AM
Soultribunal's Avatar
Most PSU's and Monitors (except the cheap cheap ones) are auto-sensing to the input Voltage.
So just grab the plugs and you should be good to go.
-ST
www.realhardwarereviews.com
Old February 1, 2012, 12:04 PM
SugarJ's Avatar
I'd check the gauge on the wire if you can, that linked cable looks awfully slim. I'm not sure it could drive a 1000w PSU. I'd be tempted to just get the cables from a local shop once you move.
Old February 1, 2012, 12:06 PM
Not only does the cable gauge look thin those plugs look scary to trust with a 1000w psu
Old February 1, 2012, 02:27 PM
Its twice the voltage so they probably dont need as thick a wire.
Old February 1, 2012, 02:40 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Ding ding ding ding!!
Correct answer.
Old February 1, 2012, 02:42 PM
Correct answer.
Care to explain? What about the amperage and such?
How can you have twice the power but thinner wires? Shouldn't that be the opposite way? Because from what I understand its 240v there and only 110v here.
Old February 1, 2012, 02:49 PM
sswilson's Avatar
IIRC P=IE, so in order to produce 1000W with twice the voltage you'd only need half the current draw.
Old February 1, 2012, 02:56 PM
SugarJ's Avatar
Ahh, yes, I'd forgotten that you'd only need to draw 6 amps or so.
HX1000 Worth it? Blu Power Supplies 15 April 16, 2011 01:32 AM
HX1000 enough for two 5970's? Rebellionelite Power Supplies 50 May 11, 2010 09:02 PM
[WTB] Cooler Master Cosmos S, Corsair HX1000 futures Buy/Sell & Trade 1 May 14, 2009 12:46 PM
[FS] Almost Brand New Corsair HX1000 1000W Power Supply Bluefusion Buy/Sell & Trade 10 February 13, 2009 01:29 PM
