Old January 30, 2012, 02:39 PM
Fixed, it was the motherboard! Thanks for telling me this because if I didn't know I could connect those things I probably would've taken it to a shop to check and get charged some crazy amount to see what it was. T
Thanks everyone!
Old April 5, 2012, 10:53 PM
I had this same question recently and a few people on another forum told me that you should have no problem using a 4 pin connection in an 8 pin plugin as long as you're not overclocked or your running a core 2 duo or core 2 quad rig. Taking their advice i plugged my 4 pin connector into the 8 pin slot and i've been using it that way for a few months with no problems.
Old April 6, 2012, 03:43 AM
KaptCrunch's Avatar
PSU priority hardware be it dell,HP,comqac if have a volt meter check old unit for polarity or take a pic of it so we can ID what you have
4+4 pin CPU connector vs 8 pin ATX connector sstrucel CPU's and Motherboards 1 August 5, 2011 07:45 AM
Which connector do I need? Fudd Rucker Water Cooling 13 January 25, 2011 09:18 AM
[WTB] Need a wc'ing sli connector G777 Buy/Sell & Trade 6 November 24, 2010 06:02 PM
Anyone seen a 3>1 fan connector around? Jmark Water Cooling 5 October 19, 2009 03:33 PM
8 Pin 12V ATX Connector element291 Power Supplies 6 August 24, 2009 08:52 PM
