Old January 26, 2012, 07:44 AM
Default UPS
I want a ups for my specs:
Intel core i7 2700k @ stock speeds
Asus p8z68vpro/gen
gskill 16gb ram @2133mhz
Amd radeon hd 7970
benq 2420tx
corsair ax850 psu
250gb hdd
It should give at least 10min backup at full load since my father do sound editing and he takes time to shut it off?
Old January 26, 2012, 07:50 AM
supaflyx3's Avatar
APC BACK-UPS RS 1500VA 865W 10 Outlet 420J RJ-45 Protection - AMERICAN POWER CONVERSION - BR1500G
That should be enough to handle his computer and monitor for a few minutes to shut down.
Old January 26, 2012, 07:55 AM
stoanee's Avatar
10 mins might be tough @ full load, might as well go big or you will own an expensive paperweight:
Cyberpower CP1500O 1500VA UPS Battery Backup Pure Sine Wav w/ 10 Outlets at Memory Express
heatware
Old January 26, 2012, 08:14 AM
Soultribunal's Avatar
Both of those are good UPS units.
MIght get a bit of a noise thing though if they go on backup batteries because the Sine wave is a stepped approximation and not pure or true.
Active PFC PSU's sometimes don't like that (and its been contended both ways).
But yes, those units should do the job You're probably not on the Cusp of your load anyways. I bet you pull Max 550W from the wall. SO the units listed will give you about 20. Roughly. Maybe more if my math is wrong.
-ST
www.realhardwarereviews.com
Old January 26, 2012, 08:17 AM
supaflyx3's Avatar
The one stoanee linked is listed for 11 minutes at half load, the one i linked i have no clue but probably around the same.
Old January 26, 2012, 08:19 AM
stoanee's Avatar
Ya my math sucks, I have the Cyberpower 850 and all it can do is shut off my SR2, barely.
heatware
Old January 26, 2012, 08:28 AM
Yeah he should be fine though because I bet he isn't pulling half load even on one of these.
-ST
Old February 17, 2012, 10:06 AM
APC has a product selector that might help :
UPS Selector Sizing Applications=
I just picked up APC's BR1300G at Costco yesterday for $144.99. Might be all you need. The On-line store has the bigger models.
ASUS Z97-DELUXE; INTEL i7 4790K ; NOCTUA NH-U12P; PNYGeForce GTX 760 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 10 PRO 64-BIT.
