-   -   6pin to 8pin (http://www.hardwarecanucks.com/forum/power-supplies/50893-6pin-8pin.html)
kyle_L January 24, 2012 09:42 PM
6pin to 8pin
so i am wondering if its possible to get a 6pin to 8pin adapter for my power supply. i currently have 1 6970 that takes 2 8pins and would like to add a second 6970 to run crossfire, my power supply has more than enough amps and watts to handle both cards except i have 2x8pin connectors and 2x6pin ones, anyone got any ideas.
SugarJ January 24, 2012 09:54 PM
NZXT Premium Individually Sleeved Computer Cables 6+2PIN to 6PIN Video Card Extension Cable Adapter - NZXT - CB-8V
kyle_L January 24, 2012 10:15 PM
thanks man, that was fast, i looked and looked and must have missed it, thanks again.
enaberif January 24, 2012 10:21 PM
the extra 2 are just grounds you can use the cards without them I think it just disables overclocking ability
