  #21 (permalink)
Old March 23, 2012, 05:33 AM
krazyups's Avatar
Originally Posted by siegfx View Post
I've contacted the company, and they said they can't take it back if it's just because of the noise (like an old TV)... So I guess I'm stuck to buying a new PSU , and sell this one later on to someone who uses Fan cooling / not interested in silent PC.
Would a seasonic X-1050 be silent ? I noticed that the Coil sound is louder the higher the PSU wattage is.. (I went from a Coolermaster Silent Pro 1000W) So I guess I wont be taking anything close to a 1200W for now.
The seasonic unit would operate in fanless mode when your system is idle, so the fan wouldn't be spinning at all.
You can look at different reviews of whatever PSU you're think about getting to see about the fan noise. If the PSU hasn't been reviewed here, I recommend checking out jonnyguru.
  #22 (permalink)
Old March 23, 2012, 06:17 AM
Lsv's Avatar
Lsv Lsv is offline
It's coil noise in this one, krazyups - https://en.wikipedia.org/wiki/Coil_Noise
OP - Crappy buzz man, a lot of high end PSUs get coil whine probably because the experienced engineers are old and cannot hear those high pitched sounds anymore. Allowing the PSUs to go into production. Need some young guys in QA I say.
  #23 (permalink)
Old May 31, 2016, 06:39 PM
THS THS is offline
Necro bump. Sorry.
My AX1200 is having the same issue.
It is NOT coil whine. It's the fan. There is a YouTube video on this. Google AX1200 fan replacement.
I am now looking for a replacement fan for this. Out of warranty so corsair can't help.
  #24 (permalink)
Old June 1, 2016, 01:09 AM
Dzzope's Avatar
Check out EVGA too, they are damn good supplies.. (B2, G2, GS, P2 lines)
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
  #25 (permalink)
Old June 1, 2016, 10:36 AM
THS THS is offline
Don't need a new PSU as this AX1200 works fine. Just need to replace the fan.
  #26 (permalink)
Old June 1, 2016, 10:48 AM
Arinoth's Avatar
I have a CX750 I've been meaning to replace the fan but I haven't found a 140 mm fan with the connector already on it that PSUs use.
Here I am: here I remain
AX850 or AX1200 for SLI GTX480 OC'd Beastylemon Video Cards 6 September 23, 2011 01:21 PM
Low 12V rail on Corsair AX1200 Prolab Power Supplies 6 August 6, 2011 06:58 PM
Most silence and speed? debbie New Builds 23 May 13, 2011 01:26 AM
Silence is Golden Wurmer Video Cards 12 April 10, 2011 07:35 PM
My Antec 300 on its way to Silence and Performance CoolHandL Case Mods, Worklog & Gallery 12 April 16, 2010 08:33 AM
