Old January 24, 2012, 07:19 PM
Soultribunal's Avatar
I would still see what Corsair says. Start a support ticket.
-ST
www.realhardwarereviews.com
Old January 24, 2012, 08:49 PM
And if you won't need the cash right away you can buy a new PSU and then sell the one you get back from RMA.
Old January 24, 2012, 08:56 PM
I've contacted the company, and they said they can't take it back if it's just because of the noise (like an old TV)... So I guess I'm stuck to buying a new PSU , and sell this one later on to someone who uses Fan cooling / not interested in silent PC.
Would a seasonic X-1050 be silent ? I noticed that the Coil sound is louder the higher the PSU wattage is.. (I went from a Coolermaster Silent Pro 1000W) So I guess I wont be taking anything close to a 1200W for now.
Old January 24, 2012, 09:06 PM
If it's idle coil whine and it goes away when you load the system, turn off power management features like C-states or w/e you have in your UEFI. Most high quality PSUs often have random coil whine issues with higher quality power delivery on motherboards.
Also, is there any particular reason you use a 1kw+ unit on a system that really only needs ~800w? Pricing in Australia is pretty bad last time I checked.
Old January 24, 2012, 10:09 PM
Ok I'll see my bios soon.
The only thing that pushed myself to buy over 1KW unit is for future proofing.. when the next gen high end GPUs are out, I'm planning to get 3 of them.. I just want to have sufficient power for that time.
Yes, the pricing is bad as usual
Old February 26, 2012, 05:27 AM
Trial Member
Originally Posted by siegfx View Post
Hey guys, I just got my AX1200 today, and I noticed that it's quite loud..
Would any of you recommend any fan to replace the AX1200 Fan?
Voiding the warranty wont worry me so much, as long as it's dead silent.
Cuz I'm using a fully water cooled system, and I use lots of push pull silent fans on lower rpm, so the only thing that I can hear very very clearly right now is my power supply.. x_x
Hey,
I know what You mean , my AX1200 has the saem fan crap noise and it makes me mad !! . its 100% fan - jsut stop it and ull see . I RMA'd this PSU 3 times now AND ALL OF THE HAVE THIS SHIT NOISE which makes ma lunatic! So if You have possibility then jsut go and buy something else or face the possibility to be lucky on RMA process and get the unit without that pissing off noise. BTW anyone wanna psot a tutorial how to swap fans in this unit ?
Old March 20, 2012, 08:40 PM
NickHellish's Avatar
Mine doesnt do this and I am using more wats then the computer in your bio.
Old March 21, 2012, 04:48 PM
b1lk1's Avatar
That PC would be lucky to pull 600W through the wall.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
  #19 (permalink)
Old March 21, 2012, 05:26 PM
If they can't RMA coudln't you get dangerous and replace the fan? I saw Daz do it once.
  #20 (permalink)
Old March 23, 2012, 12:55 AM
bigFOIG's Avatar
Changing the fan (which isn't really dangerous) doesn't help coil whine
AX850 or AX1200 for SLI GTX480 OC'd Beastylemon Video Cards 6 September 23, 2011 01:21 PM
Low 12V rail on Corsair AX1200 Prolab Power Supplies 6 August 6, 2011 06:58 PM
Most silence and speed? debbie New Builds 23 May 13, 2011 01:26 AM
Silence is Golden Wurmer Video Cards 12 April 10, 2011 07:35 PM
My Antec 300 on its way to Silence and Performance CoolHandL Case Mods, Worklog & Gallery 12 April 16, 2010 08:33 AM
