Old January 19, 2012, 02:42 AM
Default Which Brand Power Supply and what is needed,watts,etc?
Intel Core i7 2600k
Sapphire Radeon HD 7970
Z68
Apple Wireless Keyboard
Apple Magic Mouse
2TB HDD
1TB HDD
4gb x 2 1600mhz DDR3 Ram
DVD Writer
LG IPS LED 27inch 1080p
Long period usage,overnight for many days
1)How many Watts needed?
2)Is all this needed 80+ GOLD,BRONZE,SILVER?
3)Any extra cables to buy?
4)Which brand? - not to cheap out,just detail if cheap is good or expensive ones are good
5)in-Brand specific - Which model of that brand and what series?
Give another recommendation for the following things added to the above config:
Dual Display connected to GPU
bluetooth card
Wi-fi card
SSD
Speakers
Headphones
USB Mouse
USB Keyboard
Old January 19, 2012, 05:14 AM
Avenger212's Avatar
Do you want a modular powersupply? I can say that the best brands for a powersupply right now would be from Corsair, Seasonic, XFX, Silverstone and Antec. My personal preference would be powersupplies from Corsair and Seasonic. Because you can never go wrong picking them and the sleeving is black I can't even see the colours of the wires. (In Corsair's case even the wires are black so its pretty hard to Identify them inside the sleeving.) But I estimate you should be fine with a 550-650watts for your rig and if you don't plan on adding a second Graphics Card. Otherwise if you plan on CFX with those I estimate 750-850watts.
Old January 19, 2012, 07:11 AM
Silent_Avenger's Avatar
Don't skimp on the PSU it may be tempting to get that $100 850W PSU you see but it's not worth it. Quality is what you want here since it supplies the life blood of your system. A 650W from Corsair, Seasonic, or XFX should be enough to put you in optimal power efficiency when under 100% load. The 80+ power ratings do matter. Basically the lower 80+ ratings (Bronze) waste more energy converting from 120V AC power to the DC power and voltages you need. This wasted energy is converted to heat. So if you get an 80+Gold PSU it will use less energy and produce less heat. Should you get an 80+gold PSU? Probably not, 80+ gold is only suitable for those very energy conscious or if you're going to be running your system at 100% load 24/7(like a dedicated folding rig). Extra cables to buy? You shouldn't have to buy any extra cables with a PSU since usually PSUs have enough cables for what they are rated to power for example a 750W PSU can power 2 GPUs and therefore has 4 PCIe power connectors. However, sometimes if you're in a large case you may need to get extensions for some connections to do nice tidy cable management. Different models in the top brands usually don't have many differentiating features the most noted ones are modular vs non-modular and warranty length.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old January 19, 2012, 07:17 AM
uh lots of sub $100 to $100 power supplies work just fine. don't get a power supply based of bronze silver or gold. Figure out a budget and your overall plans for a system then buy a power supply based off that.
Old January 19, 2012, 05:15 PM
you would go with corsair 600W but i would get 850W just for extra power for overclocking and crossfire
Old January 19, 2012, 05:33 PM
Bond007's Avatar
buy a 650w seasonic, corsair, xfx, or antec and you'll be good to go.
Old January 21, 2012, 07:08 AM
neo678123's Avatar
corsair gaming gs800 :D
Old January 21, 2012, 10:09 AM
crossfire/sli can be done on a 600w depending on cards and overclocking isn't that power hungry
Old January 21, 2012, 10:43 AM
Adzsask's Avatar
Antec Earthwatts 750W Modular Power Supply ATX12V V2.2 EPS12V Active PFC 80PLUS 135mm Fan - Antec - EA750
this would do, but i would toss in the one below in case of an upgrade or two
XFX 850W PRO850W XXX Edition Single Rail ATX 12V 70A 24PIN ATX Modular Power Supply 80PLUS Silver - XFX - P1850BNLG9
Watts needed for SLI? b1ack1otus Power Supplies 17 January 5, 2012 06:24 PM
[WTB] POWER SUPPLY 500 WATTS AND MORE. _dangtx_ Buy/Sell & Trade 60 October 1, 2009 09:20 AM
[FS] Almost Brand New Corsair HX1000 1000W Power Supply Bluefusion Buy/Sell & Trade 10 February 13, 2009 01:29 PM
1KW Power Supply Needed.... mlauzon Power Supplies 11 December 23, 2008 05:48 PM
Best Power supply in either 600 watt or 700 watts Dashock Power Supplies 22 July 23, 2008 08:22 PM
