Old January 17, 2012, 10:59 PM
Default i have a power supply question.
Ok here is my current system: (keep in mind i am still upgrading)
CPU:AMD FX-8150 @3.6ghz(some say it sucks,but i have been running with it for 2weeks now,and i am very happy with it)
CPU COOLER:Cooler Master Hyper 212+
MOBO:ASUS ASUS Sabertooth 990FX
GPU:EVGA GeForce GTX 460 SE 1GB(will be upgrading soon to an XFX black edition 7970)
RAM:2x4GB Crucial Ballistix DDR3 1600mhz
CASE:Cooler Master HAF 932 Advanced
PSU:Ultra X-Pro 600w
HDD: Seagate 1.5TB SATA II
I am now trying to pick a power supply, i have 2 i am looking at,one is a Corsair, the other is a Cougar (which if i remember right is the brand of a PSU you used in your test bench for a while,or you may still be using it idk lol) and i would like to know if you would suggest that brand PSU? cause it is cheaper than the Corsair,and that extra saved money would help me to get an SSD later.
If this helps here are the 2 PSU's i am looking at:
Corsair
Corsair Professional Series HX1050 1050W ATX 12V 87A 24PIN ATX 80PLUS Silver Modular Power Supply - Corsair - CMPSU-1050HX
Cougar
Cougar Cmx Series 1000CMX 1000W ATX 24PIN 80A 12V 80PLUS Bronze 140MM Modular Power Supply - Cougar - 1000CMX
Some of you might say that much wattage is over kill,but i want to be able to have the option to load up my mobo with parts with out having to change PSU's agian,also i plan to use the PSU till it dies on me.
P.S. Linus, i did not get the Crosshair V mobo like you suggested,cause i picked one up,and the rig would not boot,and it turned out i would have to do a bios update,and i did not have an AM3 cpu to do so,and the store i bought it at would do it for me,but they woulf of charged me 40$,and i would had to of left it overnight,and i live 50 miles from that store,so that was a no go,i looked at the store at the intel mobo,and there were none in my price range that the stuff i wanted,but the Sabertooth 990FX was sitting there and said FX firmware ready.
Thank you so much linus(and anyone else) for the help.
Old January 18, 2012, 12:22 AM
Avenger212's Avatar
I would go for the Corsair Series, Just because it is a single rail power supply and you don't have to worry about plugging too much in one rail.
Old January 18, 2012, 06:28 AM
I would go with a corsair power supply as well, its a bit more money but I think you will find that it is worth the price when your PSU does die and take your components with it!
Old January 18, 2012, 07:54 AM
stoanee's Avatar
I recommend the Corsair or Seasonic Gold series power supplies. You also cannot go wrong with Corsair HX750, HX850.
heatware
Old January 18, 2012, 08:46 AM
corsair
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old January 18, 2012, 09:06 AM
NI3 NI3 is offline
I recommend the corsair because it is 80+ silver, while the cougar is only bronze, as well as the single rail. They are both good, but the corsair is better, and worth the $23 more.
[FS] Various Computer Components (Nothing right now) Asad_A203 Buy/Sell & Trade 18 June 8, 2012 08:02 AM
Uninterruptable Power Supply Question enaberif Off Topic 9 July 22, 2011 12:55 PM
Power Supply Question r0k0 Overclocking, Tweaking and Benchmarking 15 April 11, 2011 06:08 AM
Power supply and UPS question r0bc Power Supplies 9 December 7, 2009 07:31 PM
