-   -   Need help Newbie Question (http://www.hardwarecanucks.com/forum/power-supplies/50599-need-help-newbie-question.html)
gemdse January 17, 2012 09:04 PM
How do you determine the compatibility of the PSU and Chasis?
Will a CMaster M600w Silent Pro modular 80+ fits with CoolerMaster Elite 430?
Please help.. Thanks
Silent_Avenger January 17, 2012 10:19 PM
Most of the computer stuff is pretty standardized now. Your case is labeled as an ATX Case and your PSU is labeled as an ATX PSU as well so in all likely hood they will work together. You just have to make sure your PSU will have enough plugs for all your hardware. You may also want to steer clear of CM power supplies. You may want to look into Corsair or Seasonic. They cost more but will save your money in the long run.
Dragonstongue January 18, 2012 08:05 AM
Well CM does make some good power supplies, if you want to use it, be sure to research the crud out of it first, there is one site I go to all the time for this, they do overload test and such, so at least you can see the raw numbers to know if it is "safe" to use and what its limits are.
Now I dont know about the Silent Pro series, but my previous CM power supply Pure Power 750 was actually slightly shorter then my current HX750.
ATX specs usually have a version number such as ATX v2.1, I believe this has a defined limit on power, as well as dimensions.
But in regards to spacing concerns, I highly doubt you wil have issues in that regard, they have a review here on hardware canucks for the 430 ELITE, and it looks quite roomy.
Another good, lower cost case, would be Raidmax Viper, might be worth looking into, if you are just looking for something currently.
Power supplies, me it would be Corsair, Seasonic, Antec, Silverstone, XFX, NZXT Hale. HX750, TP new 650 or 750, Strider gold, HALE 85+ and such.
Antec TP new 650 is an excellent unit, as is Corsair TX v2 650, CM does make good stuff, but they are also on the lower end of PSU manufacturers, there are better choices, sometimes only a couple $ more expensive, but, reviews always are worth thier weight in gold :)
