what power supply? I need a new power supply i have: an intel i5 2500k 8gb ram (dual channel) a samsung 1tb 5600rpm hdd and a Nvidia gtx560 ti superclocked what power supply shall i use (watts) thanks neo:thumb: |
I will say a quality 550-650watts should be more than enough for that build. But I will go for the 650watts just for more headroom. |
Quality 500w bare minimum if you don't think you will do OCing. I would go for something (as mentioned above) 550-650w so there is lots of headroom. Grab a seasonic, corsair, xfx, or most antecs. |
i think i'll choose the cooler master 650w :D |
-ST |
Definitely prefer Corsair and Seasonic with Antec close behind. I typically use Antec EarthWatts in more value-minded builds. |
+1 for corsair... have been using AX850 and AX1200.. quiet and very stable. |
how about the Corsair Gaming GS700 |
| All times are GMT -7. The time now is 10:57 AM. |
