Old January 10, 2012, 08:37 PM
Default How much could I load my corsair TX 750 V2
Hi,
I have a corsair TX 750 V2 PSU
I currently run a
Intel 2600k
P8Z68-v gen3 mobo
2x4Gb of corsair vengeance 1600 Mhz ram
EVGA GTX 580
A blue ray combo drive
a crucial M4 SSD
and a laptop toshiba 5400rpm hard drive
I intend to watercool the CPU and graphics card
will my PSU be enough to run a second GTX 580 or do i need to change it when I go SLI?
Does anyone have maximum power consumption of the items listed above?
and how many watts of a margin do I need to leave to be on the safe side?
thanks!
Old January 10, 2012, 09:20 PM
Soultribunal's Avatar
I like to leave between 100-150W as 'breathing room' on my PSU's. Although yes they can power things up to 100% of there rated capacity, it will shorten the life of it if you do that.
That being said I would prefer to see an 850-900W for SLI580's.
You could probably do it on the TX750 but it would be really tight.
-ST
www.realhardwarereviews.com
Old January 10, 2012, 09:23 PM
Thanks!
Ill upgrade then to be on the safe side....
now that my build is complete, i have to infest the watercooling forum with my questions to put together a custom WC-ing system
Old January 11, 2012, 04:37 AM
Bond007's Avatar
I wouldn't go sli 580 on a 750w either. Min 850w IMO.
Old January 11, 2012, 08:34 AM
I have heard of people killing their corsair 750w units with SLI 580's so personally i wouldn't try it.
Old January 11, 2012, 08:39 AM
Arinoth's Avatar
Nope, you can't really run all that on a 750W power supply if you plan to overclock them or watercool them. I was running 2 580s with the more power hungry i7 940 and I could easily exceed 850W when they were all fully loaded and overclocked.
Running on SB though I can't seem to push over 850W when I had the 580s.
Here I am: here I remain
Old February 12, 2012, 12:00 AM
THS THS is offline
Grab a 1000W like corsair HX1050W :)
smp 8 = 13% CPU Load? zoob HardwareCanucks F@H Team 4 January 19, 2011 04:18 PM
BFG 260 won't Load up on my DFI p35 lanparty mb Shadowmeph Troubleshooting 6 August 11, 2010 01:57 PM
www.hardwarecanucks.com won't load without the www. Pax Suggestions & Feedback 11 June 13, 2010 09:13 PM
BF BC2 Load times Rison Gaming 2 April 18, 2010 08:21 AM
High load on a UPS odis172 Power Supplies 3 January 11, 2010 11:12 AM
