Old January 9, 2012, 09:42 PM
Default Enough Power?
Just curious if a corsair TX750w will be enough to power crossfire 7850's and an overclocked i7-3820 with an ASUS Rampage IV motherboard. I will be having two hard drives one 640WD black and 1 120gb SSD. I will wait to see the final power specs of the 7850's but curious to see if other people are running crossfire/SLI setups off a 750w PSU.
Old January 9, 2012, 09:52 PM
easily :p
Old January 10, 2012, 05:00 AM
Arinoth's Avatar
It should be able to handle it.
Old January 10, 2012, 05:10 AM
Soultribunal's Avatar
Yuppers 2 460's , 1 430 and an i7 930 off of a 650W HX.
You should be fine,
ST
Old January 10, 2012, 01:34 PM
Had this discussion on another forum.
a heavily overclocked i7 3960X with 2 overclocked 7970 will chew approx 680w at very hard loads, so 2 7950 and the rest of said system should be able to be fed fine off a decent to good quality 750 without issue.
Just on wattage
7970=250w(is well within this range even when overclocking)
CPU=130watt as long as you dont overclock to high heaven
system=60watt or so
690watt with very heavy load/overclock which simple numbers is approx
57amps off of 12v and I believe it would not be that high to be honest.
So, you should be A ok :)
[FS] Various Computer Components (Nothing right now) Asad_A203 Buy/Sell & Trade 18 June 8, 2012 08:02 AM
OCZ Technology Unveils the PC Power & Cooling Silencer Mk III Power Supply Series Sam_Reynolds Press Releases & Tech News 8 November 9, 2011 07:48 PM
