Originally Posted by Soultribunal While 700W is enough to power up to a GTX580 the one you have should not be used or even considered powering a new system.
There are very good reasons for it to NOT have PCI-e connectors. THat is namely because the unit I doubt can actually do 700W worth of real power.
It is not made by any good OEM, and from just a quick search on the net I see a lot of complaints of it killing system components.
My advice? Ditch that one and get a good unit from Silverstone, Corsair, Seasonic, Antec.
For your setup, 650W quality unit would be more than capable even if you want to do SLI.
-ST |
I second this, personally I have been burnt to many times by cheap/old PSU's. If you want to save money, cheaping out on the power supply is not where to do it!
