-   -   what size psu (http://www.hardwarecanucks.com/forum/power-supplies/50025-what-size-psu.html)
jimmyb007 January 3, 2012 08:29 AM
what size psu
im a bit stuck at what size psu i need
i will be upgradeing my system too:
asus m4a89 gtd pro
amd bulldozer fx 6100 6 core processor
xfx radeon hd 6970
500gb hard drive
64gb ssd
8gb corsair vengence
2 optical drives
corsair h60
and 4fans
thanks
krazyups January 3, 2012 08:50 AM
Any quality 650W supply will be more than enough to run that system. I'm running a Seasonic X650, and it handles my unlocked (and overclocked) 6950 and heavily overclocked 2600k just fine.
Avenger212 January 3, 2012 08:55 AM
I would recommend 650watts as it is more than enough power for all of those components and a bit of headroom for OC. I would say a power supply from Corsair, XFX, Seasonic, Silverstone or Antec will do the Job just fine.
jimmyb007 January 3, 2012 08:56 AM
would a XFX 650W XXX Edition Modular '80 Plus Bronze' Power Supply be ok to use
Bond007 January 3, 2012 09:29 AM
Most seasonic, corsair, xfx, or antec that are >600w will be fine. The XFX you mentioned is good to go for the task.
Birk January 3, 2012 09:50 AM
keep in mind any expansion in the near future and leave your options open. 650 will run it but think about maybe 750 or 850 for a few dollars more and have some wiggle room
Bond007 January 3, 2012 10:22 AM
agreed. If you may crossfire then go for an 850w.
