-   -   Is this PSU good for this rig? (http://www.hardwarecanucks.com/forum/power-supplies/49265-psu-good-rig.html)
Benzil December 9, 2011 01:44 PM
Cooler Mastes Silent Pro M600
Silent Pro M600 - Cooler Master - Leading Provider of Computer Case | Cooler | Power Supply
Phenom x6 1090T @ 3.6Ghz
4GB DDR3 Kingston x2
MOTHER GIGABYTE GA-970A-UD3
Zotac GTX560ti
HDD 1TB SATA II
Thx.:ph34r:
KaptCrunch December 9, 2011 02:17 PM
caution with the cables are all same colour can mix pci-e and MB power connection
CM to cheap to mark whats what use a volt meter to check polarity
http://t1.gstatic.com/images?q=tbn:A...hnnUdDPi2uxbRA
frontier204 December 11, 2011 06:56 AM
I haven't seen a review that dismantled or properly tested that power supply like Hardware Secrets or JohnnyGuru, so I can't recommend that CoolerMaster. I haven't heard of them blowing up yet, but you can get some units that did go through good reviews for the same price.
Assuming some not-insane overclocks, your actual power consumption should be 260W (stock) -370W (overclock with voltage bump) so you are shopping in the right wattage range to give you some headroom (500-600W).
Take a look at the following:
Newegg.ca - SeaSonic S12II 520 Bronze 520W ATX12V V2.3 / EPS 12V V2.91 80 PLUS BRONZE Certified Active PFC Power Supply
Antec High Current Gamer 620W 48A 24PIN ATX12V V2.3 Active PFC 80 Plus Bronze Power Supply 135mm Fan - Antec - HCG-620
Depending on sales, you may be able to get a Corsair 80+ Bronze unit around the price of that CoolerMaster as well.
Avenger212 December 11, 2011 07:09 AM
I will testify against Coolermaster power-supplies ! I fell victim to it when I bought it and exploded several months ago taking some hardware with it. I say go quality when it comes to power-supplies like the ones from Seasonic, XFX, Corsair, Antec. Also don't buy Thermaltake power-supplies either I fell victim to that too.
