Old December 3, 2011, 12:00 AM
Jake_HT's Avatar
A 1000W will do you just fine. And have plenty of headroom.
1500W is a LOT of power, like everyone else is saying, 4 video cards will net you close to that. 2, will not.
2x 6970 @250W TDP = 500w
i7 2700k 95w
HDD 15W Each = 75
10 fans at 3w each = 30w
2x DVD drives = 60w
Motheboard/ Ram = 25w at most
A 1000W PSU will easily handle your load, keep in mind it's nearly impossible to run ALL components at 100% load, which is what quality power supplies are designed to be runned at, they can handle more.
A 1500w PSU simply isn't necessary for a dual GPU/single CPU build, no matter how extensive your component section is.
http://jakeht.deviantart.com/
Old December 6, 2011, 04:55 PM
I agree. A 1000W psu will be sufficient and also provide futureproofing in case you plan on doing tri- sli/xfire down the road. I use the 1000W silverstone strider gold.
Old December 6, 2011, 04:59 PM
sswilson's Avatar
Maybe he really intends to run an OC'd BD, but he's ashamed to admit it...... That would explain the ultra-high power requirements.... ;)
Old December 10, 2011, 04:43 PM
lol definitely not doing a BD but even the oc'd 2600k can pull a little over 200 itself.
Hey Linus! Intel or amd? PcWizTech New Builds 19 November 15, 2011 12:29 AM
Linus Q&A enaberif Suggestions & Feedback 45 October 2, 2011 09:13 PM
