Old November 20, 2011, 09:59 AM
martin_metal_88's Avatar
Default -5V ATX
Hey guys!
I am searching a PSU for a client that still have a -5V pin in the ATX 24pin connector. Apparently his mobo need it to post.
Can anyone tell me why this particular pin have been removed and also, if you know any PSU that still have it?
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old November 20, 2011, 06:04 PM
no? no one?
Ask for more
Martin_metal_88
Old November 20, 2011, 06:13 PM
-5v is a old ATX standard if I recall correctly which isn't found on modern psus cause it provided power for the ISA bus.
If you need a power supply that has -5 you'll need to dredge up an old 20 yr old PSU that most likely will not work on newer hardware.
Old November 20, 2011, 09:28 PM
MacJunky's Avatar
You can find cheapo off-brand P4 compatible PSUs with -5v in some mom&pop PC shops.. at least where I live.
I seem to recall snipping the -5v on a couple because the Power Mac motherboards I was dinking with at the time did not need it. :P
Old November 20, 2011, 09:31 PM
Birk's Avatar
i might have one in my computer graveyard i'll take a look for you if you'd like.
Old November 21, 2011, 05:46 AM
Since it's for the ISA controller it's impossible that the guy mobo need it. it's a 2-3 years old asus that wont power up and the guy is 100% sure it's the PSU and absolutly want that pin because he said it's for the power button...I'll just send him walk away...
Ask for more
Martin_metal_88
