Old November 3, 2011, 12:46 PM
bvsbutthd101's Avatar
Default [NEVERMIND]Should I buy it?
Right now I can get a Corsair HX 1050w for $186.99 with $20 mail-in-rebate. Really thinking about it. Should I do it? Current specs are in my systems spec.
Old November 3, 2011, 01:00 PM
Shadowmeph's Avatar
What is wrong with your Current PSU?
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old November 3, 2011, 01:01 PM
Nothing really, I know the 600 series doesn't come out for a while but I'm not sure if my current PSU can handle a gtx 680 (if that's the name)
Old November 11, 2011, 08:48 PM
Ibekrazy6988's Avatar
Unless you absolutely want to, or go SLI the TX750 is more than sufficent for your current and future single card needs.
~Krazy~
