-   -   Looking for PSU advice for 560 Ti (http://www.hardwarecanucks.com/forum/power-supplies/47526-looking-psu-advice-560-ti.html)
Skychan October 21, 2011 08:00 AM
EVGA 560 Ti Superclocked (900mhz) min requirements state 500w w/ 30amps total power on 12v rails.
My Enermax Liberty 500w PSU meets these reqs (has 32a).
I just wanna be sure I'm not gonna push it past the limit since my CPU has major OC.
Currently running:
q9450 at 3.8ghz and 1.40v
GTX 460 768mb at 860mhz
H70 watercooler
4 120mm fans
1 140mm fan
2 HDDs
1 SSD
1 DVD burner
So ya, the 560 ti has more SPUs, more memory and higher clock, so I just wanna be sure I'm not going too far. Plus, I will OC the 560 ti as far as possible... I think I've read ppl getting them over 1000mhz but I'm not sure how many ppl get it past 900mhz.
I do have an OCZ ModXtreme Pro 600w w/ 42amps that I could swap with. I just trust the Enermax as being more robust and bullet proof. The gaming machine is also a SFF and so doing a PSU swap is kind of a pain in the ass :P
I've played with PSU Calculator Lite, but it's hard to know which components affect the 12v rails, so I'm not sure.
Soultribunal October 21, 2011 08:31 AM
Although the liberties are older units, you should be just fine with a single card on that configuration. I run a LOT more than you do on 650W.
-ST
Skychan October 26, 2011 03:56 PM
Well, I got the 560 Ti and so far so good, it's running on the Liberty 500w. It even overclocks from to 1GHZ and is stable!
