<~----> Upgrade to 850w or keep 650w? - Hardware Canucks
Old October 15, 2011, 01:31 PM
wonton1017's Avatar
Default Upgrade to 850w or keep 650w?
Since I am about to rebuild my system due to a new case, HAF-X, I was thinking of getting a new power supply while I'm at it since HAF-X allows the usage of more oversized fans. (can't wait till i move my stuff into this beastly case)
Would you guys recommend me upgrading the PSU now? Or should I wait till I upgrade the graphics?
Target power supply:
Corsair AX850W
Current power supply:
Antec Truepower New 650w (such a good power supply, have three running in the house for around 2 years and their noise level never raised one bit)
Specs:
Intel i5 2600k @ 5ghz
Gigabyte Z68XP-UD3P
Noctua NH-D14 Tri fan setup
eVGA GTX560TI OC'd to 1000/2200mem @ 1.1v (might upgrade to GTX580 or SLI 560TI in the next few weeks)
G.Skill Ripjaws DDR3-1600MHZ 2x4GB
1x Samsung DVDRW Drive
2x Intel 80GB SSD X25-M G2 in RAID 0
1x G.Skill Falcon 128GB SSD
2x Red LED 12in sticks
1x 240mm CM RED LED Fan
3x 200mm CM RED LED Fan
2x 120mm CM RED LED Fan
Old October 15, 2011, 01:34 PM
supaflyx3's Avatar
650 is fine, but if you want sli or a 580 you'll want a 850W.
Old October 15, 2011, 01:36 PM
wonton1017's Avatar
How good is the AX850w compared to the Antec TPN 650w ? (besides having more watts)
Old October 15, 2011, 02:55 PM
Prolab's Avatar
Pretty good. Read through Jonny guru's review
Corsair AX850 Review
Gaming Rig:
-Swiffy 655 & 360 rad, 360 XSPC Rad, HK Supreme HF, EK D5 top rev.2, i7 3930k, 16 GB G.SKIL F3-12800CL9Q-16GBXL, Asus Rampage IV Extreme, (2) XFX 6950 w/ XPSC WB, Crucial M4 128GB & 120 GB Vertex 2 EXT, (2) 3 TB Toshiba Drive, Corsair AX1200, Win 7 Pro 64-bit
Server Rig
-AMD Athlon II 245 stock, Asus Mobo, 2 GB DDR2 Kingston, WHS, 500 GB WD Black, (5) 2 TB WD Green, (1) 2 TB Seagate HD, (1) TB Seagate HD, (1) Samsung 2 TB F4, Fractal Design R3, Antec 650 watt PS
Old October 15, 2011, 03:01 PM
^^Agreed
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old October 15, 2011, 03:40 PM
Arinoth's Avatar
Yep, you'll definitely want a bigger PSU if you want to go sli with everything moderately to highly overclocked. Also the AX850W is a phenomenal power supply.
460 SLI on 650w? Meta|Gear Power Supplies 6 September 15, 2011 01:26 PM
Quattro 850W - Upgrade? JD Power Supplies 12 December 27, 2009 08:53 PM
Corsair HX 850w vs XFX 850w Black Edition BobbyLou Power Supplies 16 October 7, 2009 06:57 PM
Bjorn 3D compares Dark Power PRO 850W and Thermaltake Toughpower 850W Babrbarossa Reviews & Articles from the Web 0 February 13, 2007 01:02 PM
