-   -   Corsair AX650 (http://www.hardwarecanucks.com/forum/power-supplies/47314-corsair-ax650.html)
Flemminr October 14, 2011 07:59 AM
Corsair AX650
Yesterday was pay day, so I just splurged $150 and ordered myself a Corsair AX650 from Direct Canada for my PC to replace the crappy OEM one. Anyone here have happen to have to have the unit or the Seasonic version (X-650) of it? If so, thoughts on it?
Soultribunal October 14, 2011 08:03 AM
They are very solid units. Try not to panic if your fan isn't spinning in it till you really load it up. Otherwise they are another great lineup from Corsair.
ST
Flemminr October 18, 2011 06:43 AM
Got the unit from Purolator this morning. Can't wait to install it into my PC.
I have to say though, the AX650 just looks like a AX750 only with a 650 label on it instead and a fewer cables. The unit has the same amount of connectors as the AX750 does, only with less cables.
