Old October 1, 2011, 05:34 AM
Question About to do full sleeving job, should I change my PSU befoire doing so?
As some of you might have seen in my last threat I ordered a full MDPC-X sleeving kit and I'm going to do that task in a wekk when it gets here.
But it recently got me thinking, I am about o sleeve my one year old XFX 750W PSU, Would now be a good time to replace it? I mean I dont REALY need more power Im only running a GTX570 with a mild OC. Im just scared to have my PSU die on me with a 100$ sleeving job and a full day of work on it.........
What do you guys think? What would you do?
PS: Im not a HUGE fan of SLi setups even if it would probably look damn awesome but realisticaly its useless for me since I mostly play wow and some random 360 ports like Darksiders
Old October 1, 2011, 11:15 AM
dragoonxx's Avatar
Another option you have is making/buying extensions for the essentials, that way, even when replacing a PSU, you wouldn't need to re-sleeve much of the PSU
Old October 1, 2011, 11:40 AM
lowfat's Avatar
Don't know much about your PSU. But most quality PSU's should last many many years normally.
Old October 1, 2011, 05:40 PM
Jonesy's Avatar
While like Lowfat I can't comment on the quality of an XFX psu, but power supplies don't typically just roll over and die within the first 5 years of use (quality ones anyways) I still have an XT power supply kicking around somewhere that works like a charm...and it is rolling on 20 years old (was used for 10 years of that)
Origin ID = xXFlatlinedXx
Old October 5, 2011, 11:31 PM
AMC AMC is offline
Some power supplies die early. However I am 99% sure that that XFX model has Seasonic internals which are the best. I would get extension cables or buy a power supply that is fully modular like the corsair AX series. Then make your own cables for it.
Sleeving Flemminr Case Mods, Worklog & Gallery 9 August 7, 2011 08:27 AM
Sleeving micul Power Supplies 13 August 15, 2010 04:16 PM
why do sleeving? LacrosseTown Guides & How-to's 19 July 6, 2010 10:48 PM
mmm sleeving lowfat Case Mods, Worklog & Gallery 31 October 20, 2009 10:53 AM
[WTB] Sleeving Job sinticfury Buy/Sell & Trade 13 June 7, 2009 09:11 PM
