Old September 27, 2011, 10:37 PM
Default PSU sleeving Questions
Hey guys,
Im pretty much done fixing up my build for this time of the year except one lat project i want to do next week, sleeving my psu/system.
Where would I get the components? something of good quality but that will not smash the bank.
And, any suggestions as to the collor I should get? I had white/red in mind or something. Included ****ty cellphone pics of my case:
Old September 27, 2011, 10:56 PM
SugarJ's Avatar
Nils has the best sleeving I've used. Don't let the international part bother you, his shipping rates and times are excellent. MDPC-X International
Old September 27, 2011, 11:00 PM
Yeah I was actualy looking at that right now, thinking of getting:
Pin-Remover 4-Pin - Save My Wallet
PR-SMWE 2,27 Euro
Pin-Remover by MOLEX - The Original
PR-MOLEX 14,45 Euro
Sleeve SMALL - VANILLA SANDS N.17
SL-S-VS 6,68 Euro
MDPC Sleeve-Kit
SL-K1-BK 35,29 Euro
Total: 58,69 Euro
That way I could do a full black sleeve+ beige accents( that would fit my TR fans)
Old September 27, 2011, 11:09 PM
lowfat's Avatar
Use a couple of staples instead of the molex pin remover. It works a lot better and cheaper.
Old September 27, 2011, 11:15 PM
Not sure I quite understand how id do that, you got a picture or something?
Old September 27, 2011, 11:18 PM
SugarJ's Avatar
I do.
I use a molex tool, but if it doesn't work first try I go back to the staples.
Old September 27, 2011, 11:20 PM
Supergrover's Avatar
All that holds the pin in is a tab, so slide the staple intoeither side, that depresses the holdback tab, pull the wire/pin out, once you do 1 you will be " oh okay this is super easy and no i didnt need the tool.
I have a bunch of those pin tools and use staples 99% of the time.
EDIT:
Gord I see you use reg staples, if you have acsses to the 1.5 inch powerstaples they work wonders since one staple is all you need, I will try and post a image in the AM so you can see what I mean. Got a couple boxes out in the shop so I have thousands.
R.I.P.
Old September 27, 2011, 11:22 PM
Okay I suppose Ill give it a try ;)
Oh and I think im in love with the color ColorX
Sleeve SMALL - COLOR-X | Sleeve | MDPC Sleeve | MDPC-X International
Old September 28, 2011, 08:38 AM
lowfat's Avatar
Originally Posted by SugarJ View Post
I do.
This is what I do. Works flawlessly.
Old September 28, 2011, 11:00 AM
Alrighty, I ordered a full kit+ some collorX , plus i just tried the staple method, it works but boy will my hand be messed up at the end of this project......
Sleeving Flemminr Case Mods, Worklog & Gallery 9 August 7, 2011 08:27 AM
Sleeving micul Power Supplies 13 August 15, 2010 04:16 PM
why do sleeving? LacrosseTown Guides & How-to's 19 July 6, 2010 10:48 PM
Sleeving :) JMCD Guides & How-to's 34 September 29, 2009 11:44 AM
[WTB] Sleeving Job sinticfury Buy/Sell & Trade 13 June 7, 2009 09:11 PM
