Old September 11, 2011, 01:50 PM
Meta|Gear's Avatar
Default 460 SLI on 650w?
I'm looking to get another 460 but am unsure if my psu can handle 2 plus everything else. Reviews show 2 460's averaging around 470w @ load so that plus my 2500k o/c'ing it doesn't look promising. Even if I could get away with it my power supply only has 2 pci-e power cables and my current 460 needs both to power it so I would need another cable for the second card.
What do you think?
If I need to upgrade I found an Antec gamer series 900w psu on Newegg for $119, would this be a good choice?
Newegg.ca - Antec High Current Gamer Series HCG-900 900W ATX12V v2.3 / EPS12V v2.91 SLI Certified CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply
RFD
Intel i5 2500K | Corsair H50 | Gigabyte Z68X-UD3H | 16GB G.Skill Sniper 1600Mhz | Gigabyte Windforce 670 OC | Antec Gamer 900W | 24" Asus VW246H
Old September 11, 2011, 02:06 PM
supaflyx3's Avatar
You'll be fine with a 650W, the TDP of the 460 is 150W, so with OCing two of them shouldnt be pulling more then 350-375W.
Old September 11, 2011, 03:06 PM
Bond007's Avatar
What do you think?
not a lot of play room left, but I would say the 460 SLI would be fine on the 650w as long as they are not OC and the 2500k isn't ridiculously OC. Reviews I have seen have 460 pulling peak under 170w each (normally less than that), so 340w for SLI, so there is definitely room on a 650w. I would say the reviews you have read with 470w for 460 in sli is likely total system power consumption (not just the gpus). That said ensure that your PSU is quality, and not a cheapy.
Old September 11, 2011, 03:21 PM
Meta|Gear's Avatar
lol, yeah I guess that makes sense, didn't even occur to me.
RFD
Old September 11, 2011, 04:34 PM
Soultribunal's Avatar
650W on a good unit is more than enough.
I got that with a 430 GT as physx on my i7 with so much other crap inside.
Its worked great for over a year now.
-ST
www.realhardwarereviews.com
Old September 13, 2011, 06:40 AM
I use to run a 460 SLI i7 920 setup heavily overclocked on a corsair tx650w and under full folding load it could pull 500w at the wall so I'd say it's a fairly even pairing.
Old September 15, 2011, 01:26 PM
MARSTG's Avatar
my sig system is powering 3 videocards (460GTX/9800GTX+/GTS250)over a 650 xfx and they work fine, kept in folding 24/7. you should be ok. Have also a radeon 4350 doing the display.
GTX480 + 9800GTX+ with PSU 650W ? gogo Video Cards 7 May 10, 2010 05:32 AM
Corsair TX 650W enough? ev0styLe New Builds 16 February 16, 2009 07:56 PM
650W For a 4850CF Build? derrXIII Power Supplies 11 August 11, 2008 12:08 PM
