-   -   Would a 620w psu be enough? (http://www.hardwarecanucks.com/forum/power-supplies/46126-would-620w-psu-enough.html)
danman789 September 2, 2011 02:36 AM
I am going to build a desktop and am confused on what psu to get.
the specs for my computer will be:
i5 2500k
Corsair h60
Asus P8P67 Rev 3.1
Mushkin Enhanced Blackline Frostbyte 8gb
MSI Gtx 560 ti hawk
lancool pck62
__________________________________________________
I was either gonna go with a seasonic 620w or a silverstone strider 750w.
please help
supaflyx3 September 2, 2011 02:54 AM
just it should be more then enough, just if you plan on overclocking heavily it might struggle.
Andy September 2, 2011 03:29 AM
Assuming you don't plan on adding a second video card it should be fine.
roh_ultima September 2, 2011 07:41 AM
even if he added a second card it'll be fine...
test system
Core i7 965 @ 3750 MHz (25x150 @ 1.35v)
2 x 560 ti
System Wattage with GPU in FULL Stress = 449W
http://guru3d.com/article/geforce-gt...-sli-review/14
b1lk1 September 2, 2011 08:28 AM
A good reputable 620W PSU will easily power that system with tons of room to spare.
danman789 September 2, 2011 02:19 PM
just slight oc, maybe bring my cpu to 4ghz. and no second gpu will be added
_dangtx_ September 2, 2011 02:27 PM
oc'ing sandy cpus doesnt warrant a phenomenal increase in power consumption. for the 4 threaded cpus it'll in the magnitude of maybe 50-100 watts. maybe :)
Bond007 September 2, 2011 04:55 PM
your fine with 620w and that build
NI3 September 2, 2011 05:05 PM
Although 620 will be fine, I suggest you go with the 750 if you can. It is always better to be safe than sorry.
test tube September 3, 2011 10:30 AM
Tons, you can run all that on a good 500w.
