Old August 29, 2011, 09:05 PM
Default Power Supply Testers
I've been having problems with my PC, and I'm thinking it may be a power supply issue, I was wondering if any of u guys can recommend a power supply tester.
From my research the Coolmax PS-224 LCD Power Supply Tester looks like the best option. However it like others doesn't have a 8-pin PCIe plug, so I was wondering if there is anything better?
Here a video to give u an idea what I'm talking about:
LCD Computer Power Supply Tester Demo - YouTube
PS 224 LCD PSU Tester &Toughpower 750W - YouTube
Old August 29, 2011, 09:37 PM
its ok,for the 20 or so odd bucks you pay.
not only it can usually tell the difference between a dud and a 'good' one, also if its a brand new psu you are
plugging in for the first time, it better fry the afermentioend 20 dollar toy than your rig :)
i always plug new psus in me unit(older,no lcd) while keeping a certain loads with some hungry fans and a pletora of old
hard drives and cd roms :) and a few water pumps and usb devices sometimes on bigger psus to generate over a 100 watts of real load
similar to booting up an i7 machine with onboard video.
Old August 29, 2011, 09:42 PM
Perineum's Avatar
Yeah, that's not a load tester. You could have a PSU that tests out fine on that thing but loses it when actually under a load.
Old August 30, 2011, 05:25 AM
martin_metal_88's Avatar
+100 000 to that. How many time a PSU can power those little sucker and fail to power a full system. best way to test a PSU is having it plugged into a computer and insert multimeter probe in the connector ( where the cable crimp )
BUT!!!! NEVER EVER DO THAT if you have no idea what you are doing!!!
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old August 30, 2011, 06:25 AM
Arinoth's Avatar
Hmm all it is a fancy Volt meter, it tells you nothing if any of your rails are actually supplying you the correct amount of current to your devices.
Old August 30, 2011, 09:31 AM
Actually, it's also one of the few things that will give you a reading of your PSU's power good signal. A faulty PG signal can result in all sorts of weird issues, but swapping a PSU will pretty much determine the same thing.
Old August 30, 2011, 12:14 PM
Perineum's Avatar
I would never recommend taking a PSU from a "dead" system and putting it into a working system to test. You could end up cooking the working system.
Old August 30, 2011, 12:19 PM
Arinoth's Avatar
For now anyways, for now
Old August 30, 2011, 12:20 PM
and thats when the tester comes into play. i fried a couple,well worth the frying, i shall add.
Old August 30, 2011, 12:21 PM
PSU tester does nothing more than say "Hey I got a live one here!"
It doesn't tell you load when crap is running which is where power supplies generally fail>!
PC Power & Cooling Unveils New 760W Silencer Power Supply FiXT Press Releases & Tech News 3 December 18, 2010 03:53 PM
[WTB] power supply 650+ power supply j-ronde Buy/Sell & Trade 1 March 31, 2009 09:45 AM
