-   -   Silverstone SUGO 05 - 300W enough for zacate & 5850 (http://www.hardwarecanucks.com/forum/power-supplies/44298-silverstone-sugo-05-300w-enough-zacate-5850-a.html)
drslump June 20, 2011 11:37 AM
Hi!
Silverstone Sugo SG05 300w
MSI E350IA-E45 AMD E350
DDR-3 1333 ELITE 4Gb
HD 500gb Western Digital green/blue or a spare 2,5"
no optical drive
i will buy a Sapphire xtreme 5850 (The card is smaller than a standard HD 5850, courtesy of the custom design PCB, measuring around 210mm long 8.25in) that have a 170w tpd
here use a E8400 whit 5850, raptor and usb audio card
hardforum.com/showpost.php?p=1034746724&postcount=19
forums.overclockers.co.uk/showpost.php?p=14828581&postcount=127
here a E5200 overclocked at 4ghz with gtx260 (tdp 190)
my APU tpd is 28w, my configuration can run smooth? but the card need 2x6pin connector (don't make myself the installation (a skilled friend) but I want to be sure, i need only molex-to-6 pin adaptor tinyurl.com/6ddboj8 to take power from the sata connector?
Connectors 1 x 24-pin motherboard connector (300mm)
1 x 4-pin ATX12V connector (400mm)
1 x 6-pin PCI-E connector (400mm)
1 x triple SATA connector (300mm +200mm +100mm)
1 x dual 4-pin IDE (300mm + 200mm)
1 x single floppy power connectors
Thanks!
SKYMTL June 20, 2011 11:50 AM
No problemo in my opinion. That system likely won't even touch the 200W mark.
dma0991 June 20, 2011 06:42 PM
I'm more concerned about the possible bottleneck that the E-350 might cause to the HD5850.
drslump June 21, 2011 03:26 AM
Thanks! In Eu shop now, 5850 & 5770 cost less than 20 euros from each other
the pc use, is download torrent, and mining bitcoin
a i3 2100 price performance is better but more expensive
case 100 euro
apu 100 euro
ram e hd 60
5850 110
