-   -   Seasonic overheating (http://www.hardwarecanucks.com/forum/power-supplies/43622-seasonic-overheating.html)
Lanboy May 28, 2011 09:39 AM
I want to know if Seasonic PSU owner notice their PSU produce more heat than other, here why :
I have this Seasonic M12D 850 watts , it blow hot air at the back like no other of my PSU do. This is on a build that according to Antec PSU calculator will require a 500 watts, and my kill-a-watt show only 360 watts in full use. At first I thought it was may be the fan that donít run fast enough to reduce the noise, but the computer crash time to time it reboot, it happen every other day. I have to send it back for RMA but I need a PSU in the waiting time, so I order another 1000 watts PSU, a real pain. But then I suspect also the RAM, but I guess it will BSOD before reboot noÖItís not my GPU since I change it and still have the same problem.
So the question, do you thing I do the good thing to order another PSU, anyway I can use the RAM one for another build latter.
Perineum May 28, 2011 09:42 AM
I doubt it's overheating, and I doubt it's a PSU problem.
mo' power May 28, 2011 10:34 AM
System specs please.
_dangtx_ May 28, 2011 10:39 AM
look up johnnyguru's review,and a few more.
then get a more accurate reading,vs case temps,and compare again :)
driftstang May 28, 2011 10:58 AM
what are you doing when it crashes from time to time? if you're only pulling only 360 from the wall the PSU is not being stressed at all. by any chance is your CPU heatsink right below the PSU intake fan?
Lanboy May 28, 2011 11:04 AM
It's not related to case temps, this PSU is running on a Antec Skeleton, the PSU blow hot air at the back and the casing of the PSU is warm,
and it's not the motherboard or CPU since I switch them and it still do the same, the only thing in commun left are the PSU and the RAM and a SSD drives , what make me think it's the PSU, it's sometime it's more warm than other, and this on iddle too.
it's a very light use PC, running 24/7 , sometime when I come in the room the PC have reboot, but it happen 3 times I was on the keyboard only browsing and PAF it reboot without warning.
Anyway monday I will receive the new PSU, if it happen again We gone look more... But something told me those Seasonic are design to run with low speed fan, that will explain why low flow of hot air go out : let say that's a 80% efficient PSU, and it's using 300 watts, that's means that 60 watts of heat is produce and if this heat is rel;ease be a slow fan it get warm inside, it's why I ask the owner of Seasonic 850 watts, if they have the same observation rearding the heat
driftstang May 28, 2011 11:24 AM
yeah i have the same PSU as you. before i changed setups the fan wouldn't spin sometimes cuz of the low load/heat on it. i think until it reaches a certain temp it wont turn on. unlike most of others which spin constatantly at idle.
since you suspect the memory have to tried testing it with Memtest or similar program?
Lanboy May 28, 2011 11:36 AM
Originally Posted by driftstang (Post 518654)
..since you suspect the memory have to tried testing it with Memtest or similar program?
48 hours Memtest produce nothing. Monday I change the PSU, if I have the same problem, ( can take 5 days before it happen) I will run the system with other memory, but those RAM was working fine in another system, unsuported by this board ?... anyway as I said I will try the PSU first and we will see.
driftstang May 28, 2011 02:08 PM
Lanboy May 28, 2011 03:08 PM
the system specs are not the problem, as I mention before AntecCalaculator ask for around 500w and this is with 50% aging , the build draw 360 watts
Asus Rampage III Gene
i7-965x
6 sticks of G.Skill F3-12800CL9T
Saphire HD 4650
Windows 2008r2 enterprise
