Old May 6, 2011, 04:43 PM
Default Supplemental PSU?
I've got a 500W Seasonic, which is probably close to being maxed out.
4 hds,
amd 635 cpu
4 sticks ddr3
6 120mm fans
ATI 5770
No cash for an upgrade, but I have an older PSU. Using the paperclip trick, would it be an ok idea to use the extra PSU to power the video card only? If that load is no longer on the Seasonic, would I have more power for 2 extra hard drives? Or is the power for the video card coming from a rail that isn't used for other things? (Sorry if my terminology is wrong).
Mike
Old May 6, 2011, 04:46 PM
FlyingFish's Avatar
That system is drawing 300w max. Probably a bit less even.
I had a Phenom II 955 quad, GTX 260, 3 hard drives, a crapton of fans, and a DVD drive in my old system and it used 294w at full load with the CPU running prime 95 and using furmark to max out the GPU.
The 5770 uses slightly less power than the GTX 260, and I'd expect that your CPU would use the same or less as the Phenom II. Hard drives don't use that much power. Fans use even less.
edit: http://www.tomshardware.com/forum/26...er-consumption
WD Caviar Blue 500 GB SATA Hard Drives (WD5000AAKS)
Interface: SATA 3 Gb/s
Read/Write: 8.77 Watts
Idle: 8.40 Watts
So you can easily add more drives.
Old May 6, 2011, 04:54 PM
good to know that I'm not using that much power, but if my Seasonic was a 250W, would sharing the load in the way I described work?
Old May 6, 2011, 05:03 PM
sswilson's Avatar
I'd imagine it would assuming that you'd start up the secondary PSU prior to starting the main PSU. The only thing extra I'd do would be to put a small load on the secondary PSU as some PSUs need a current draw to operate. In most cases they suggest a fan, but in a case like this, I'd suggest something that would indicate operation (like I light or even better an LED 120mm fan.... ;) ).
Old May 13, 2011, 09:32 PM
There is a special adapter for ATX PSU that jumps the PWR_ON pins on the main power plug. If you don't have this, your 2nd PSU will not turn on.
Old May 13, 2011, 09:36 PM
Supergrover's Avatar
He mentions jumping the green and black pins (AKA paperclip trick) in his first post. So jump the secondary PSU, turn on rig, voila!
R.I.P.
Old May 13, 2011, 11:47 PM
and you wouldn't need a load it, only with the video card (the fan will spin when power is applied)
Old May 15, 2011, 10:33 AM
There is a mod that I have seen someone did before combining 2 PSUs using a relay. It worked for him but that is not a really necessary thing to do as the 500W Seasonic should handle all that hardware without any problems even with 2 extra HDDs added.
More than one PSU? MobiusD Power Supplies 33 June 11, 2010 12:22 AM
[WTB] Dual (same) 700W+ psu, or 1200W+ psu 3.0charlie Buy/Sell & Trade 12 October 7, 2009 07:07 AM
Using 2 PSU's? magictorch Power Supplies 3 February 14, 2009 03:39 PM
Looking for a new PSU JD Power Supplies 5 June 9, 2008 06:34 PM
need PSU suggestions, current PSU isnt cutting it Rains Power Supplies 13 December 11, 2007 08:53 AM
